These are quite goodI found it on the MIXX Audio site. It is called the MIXX Tribute and they have it priced at £12. They have a few other colors like purple, blue and rose gold.
Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
I think adding a small dot of epoxy to make a small bump to the inside left ear piece near the cable inlet (major manufacturers mold it in) aid in a tactile feel so you'll know which is the left side without even looking. This is helpful in low light situations and is definitely useful for the blind to put the correct earphone into the correct ear. That would be an additive method, filing or milling out a small slot would be a subtractive method, but both would have a tactile feel.painting them is not my specialty, but these unmarked shells I am unable to tell them apart (L and R)
Ronion
- May 17, 2013
Blur uses a small piece of clear heat shrink which works very well. Ingenious really. In the dead of the night you know which side is which.
Yep, another additive method and functional. I guess it depends on the shell and your sense of aesthetics. In the case of the earphones shown the decorative metallic strip would be obstructed, that's why the careful paint job was done(?).Blur uses a small piece of clear heat shrink which works very well. Ingenious really. In the dead of the night you know which side is which.
No, it's painted badly, in fact everyone at home is still laughing because of how I've painted it and what I've used to paint it.
but... the sound... that's something else...
Now that you mention it I can see clumps of glitter nail polish or what ever you used. But you were still being careful to not ruin the aesthetics of the shell design. Of course the sound is always important.No, it's painted badly, in fact everyone at home is still laughing because of how I've painted it and what I've used to paint it.
Red colored cables look quite striking. I havent seen them again recently until now. Is there a link?I like to play with spray paint. Sometimes too much, I admit
https://a.aliexpress.com/_vPUdQi
https://a.aliexpress.com/_vczVyW
https://a.aliexpress.com/_vLBWQI
the last link I used for IEM
AsciiJC
Member of the Trade: ValphonicsFormerly known as ValSuki
Hi all! I am back with a small update on small things:
1) Planar buds will happen, just need to finalise getting a resin printer once I have enough cash on me...those things arent cheap to setup (in total $1k for a "good" setup).; I did a good amount of research on planar dynamics and their functionality, so I could and should be able to get one setup.
2) I have a personal bud I am working on! They are called the Valar v2's, with the v1's now being done as they arent anything special. These ones I want to share with you all are something I am very proud of, and is still an on going project I have been working on for the past few months.
These are little product shots that are not official yet, but are something that will be appearing on my FB page very soon!
Ronion
- May 17, 2013
He puts it on the cable and it’s clear. You have to really look for it to see it, but it’s easy to feel in total darkness.Yep, another additive method and functional. I guess it depends on the shell and your sense of aesthetics. In the case of the earphones shown the decorative metallic strip would be obstructed, that's why the careful paint job was done(?).
SlimCharles
I can't find the qianyun qian69. Any other alternative? Tried yincrow x6 and it sounds just as good, but it's a bit difficult to fit in.
1MORE Piston EO320I can't find the qianyun qian69. Any other alternative? Tried yincrow x6 and it sounds just as good, but it's a bit difficult to fit in.
rprodrigues
Can you access Spanish shopee?
If so, ask this seller https://shopee.es/fenwei9z.es about q69. He sells them in Brazilian shopee.
Update: the seller fengru.es also sells them in Brazilian shopee.
SlimCharles
1MORE Piston EO320
Thanks a lot. I'm actually gonna try to get both: I know Qian69 very well and it's just what I want. And the EO320 seems like it ticks all the boxes: warm-ish, slim, it has a mic...
Total: 35 (members: 4, guests: 31)
