Here is a chart for the FiiO EM5... for some reason I have yet to make a chart for the Yincrow RW-2000 or 3000 I will need to do that one day soon and post it.
Thank you for doing this @WoodyLuvr . Greatly appreciate it.
Ah, that's good to hear ! Thanks!These fit exactly the same as the RW-2000 if you have ever had those in your ear. If not, they are heavier than all the plastic ones, because the shell is metallic, but they aren't super heavy (I believe it is something like aircraft aluminum). I think the comfort issues with the Chaconne derive from not only being made of steel, but the stems that are so long make them top heavy. Their natural position is: trying to fall out of your ear at all times... Overall, I can listen to the RW-3000 all day; I have done just that the last 2 days at work. The Chaconne, I can listen to them for a few hours, and then have to rest a bit (but they aren't really uncomfortable for me even then).
