tendou
- Mar 5, 2012
So it's totally the same design wise? Down to the cable?Box sticker!
It shows that all the lbb have mic and lbbs don't?
Thanks, something like this would be a good start point (if they have nice bass and treble, it would be less aggressive):Can you give me some numbers? Not sure how much you need them to go up or down...
(I will test it for you, just not a EQ god tho)
Both had 3 cable options. Black (copper), plated cable (with white covers) and black w/mic.So it's totally the same design wise? Down to the cable?
Thanks for your help, LBBS added to my list.Distortion at those levels.
But if you reduce it to lets say +5db max, it works, since M2S has a lot of bass already. Not sure if I'd advise it, but keep in mind this was done in 30s with 10 band EQ and not with PEQ, so YMMV. Also using 150ohm driver for that.
Lbbs did it just fine, think you might wanna check that one as well.
Upps, sorry one more question... equalising both buds before they start distorting, which one would you say has more bass and treble?
I see. So If I get the black one without mic then it's lbbs thenBoth had 3 cable options. Black (copper), plated cable (with white covers) and black w/mic.
Difference is driver/tuning. Externally identical.
Lots of thanks, really, really helpful!!!First off all, let me link you LBBS review from @RikudouGoku. Here you can find a direct comparition of the LBBS vs M2S Pro.
Bass
M2S Pro has more bass without EQ, but LBBS can handle much more while EQ'd (max I can try is 20dbs, but Riku got it to +25).
Treble
LBBS treble is more extended and has better detail and clarity, but M2S is close.
EQ
LBBS handles EQing better, hands down.
Over the ear usage/Cable/Modular Drivers
Big selling point on M2S Pro for me is that you can use them over-ear if you want, with a cable that wish to. I'm using a cable that costs as much as the buds, but that's just because I owned it before and I don't own many mmcx cables, so I just grabed it and it looks good. Since they have ear-hooks, I used them as over-ear from the start with the 150ohm driver. This made me like M2S Pro more than LBBS at start because the sound is airy, cleaner, closer to an open back headphone.
One day, after talking to @RikudouGoku on his thread, I tried M2S Pro and yeah, it's a game changer. I prefer M2S Pro used over ear and with 150ohm driver, but when compared down vs down, I prefer LBBS no chance. I'm telling you this because if you want a V-Shape, I'll have to use them down, since over the ear will balance the sound (this is more to my liking be clearly the opposite of your preference).
If I was looking for your sound signature (Extreme V-Shape) and wanted to EQ it, I'd grab LBBS. M2S Pro would be my second bet, but I'd keep the stock driver since they sound more V-Shaped than the 150ohm driver to my ears, and use them down and not over-ear.
Conclusions
If it was today, I'd grab LBBS and be done with. They are now around 3rd of 4th on the list of my prefered buds. Just grab and go, no need to care about cables, drivers, etc, but I use them as beaters.
Hope this was helpful!
Very detailed; tad on the bright side and a bit analytical; nonetheless a very good earbud. Hard to compare to the LBBS just a different sound signature and one that punches well above it's price.Hey guys any thoughts on **** pt2021 365ohm version ? Is it sound better than LBBS ?
Unfortunately due to the exchange rates Aliexpress uses and the changes in VAT a couple of months ago, the RW2000 comes down to 158 euro for me, or 147 on the sale that's about to happen .Keep in mind, that was USD I quoted you earlier... That would be 118 euro for the RW2000. And, now that you mentioned sleeping in them, I also find them (amongst my collection) to be the best to sleep in. I am neither irritated having them in, nor do they touch the pillow putting extra pressure, being so small and light (I am a side sleeper BTW). But, even should you decide a different route, it almost sounds like you will like the shell type that these, and that the Smabats are because there are no stems to put any pressure on your ear lobes while sleeping.
Also because you will be using them in bed mostly, you might consider the cable being detachable as a must, so it is replaceable in the future.... The RW2000, and all of the Smabats have this feature also. There are cheaper options with this feature also, but I just cannot speak to the sound that they reproduce.
alright noted thanks ohya one more question how about the comfort? Is it better than normal mx500 type shell or basically feel the same when wear it ?Very detailed; tad on the bright side and a bit analytical; nonetheless a very good earbud. Hard to compare to the LBBS just a different sound signature and one that punches well above it's price.
To me they are very similar to MX500 in comfort level.alright noted thanks ohya one more question how about the comfort? Is it better than normal mx500 type shell or basically feel the same when wear it ?
Aiya then a little big for me becoz my ear feel pain when wearing mx500 type shells with donut foam for 1 or 2 hours.To me they are very similar to MX500 in comfort level.
