RikudouGoku
Member of the Trade: RikuBuds
Enjoy them for sure.Glad you did, because I very nearly passed on them, but because of your(s) (and others) review I said what the heck.
LOL I have some silicones on the way, because I could tell by the pics that they might be an issue trying to get the foams on that all polished metal dome.. I normally prefer foam-less anyhow and I thought the silicone would help hold them in place. Ironically, they don't hold too badly in my medium-small ears without anything (though I haven't tried actually moving around yet lol).Did you try the glue Just kidding. They have similar problem like Datura Pro.
If the silicone ring is not a problem due to the slightly increased diameter, then you can use foam with it. Then surely the foam will not slip
Since I got mine today, I would laugh if we both got our Smabats on the same day also.
Well, folks, my journey officially begins!
Knowing our luck, I wouldn't be surprised. It averages out, right?Since I got mine today, I would laugh if we both got our Smabats on the same day also.
No words have been more true! LOLKnowing our luck, I wouldn't be surprised. It averages out, right?
The last time I heard staging and space like this, I had on a set of Ether Flow Closed. Are you sure these are $10?
Obv no real subbass to speak of, but man I love how weightless they are in the ears. Granted, this isn't the only genre I listen to. Acoustic stuff is much more pleasant.
Will definitely have to get used to fit, though. IEMs are so foreign, in comparison.
Yep. Guess that's Amazon's default config. I think your DX300 will be up to the task, though, even in SE.Is the cable 3.5mm SE? Was just curious because I chose to have 2.5mm for my buds. I have the litz 2.5mm to 3.5mm SE adaptor that came with my IT07 that I can use on anything that doesn't have 2.5mm balanced.
Are you maybe talking about TG-38s? This happens every time after two year of using it, and they trick me every time.No words have been more true! LOL
It will get better. Wait till that one song comes along that just hits you and you look around, swearing someone else made that noise... I honestly think that these little buds an compete with the famous HD800 for soundstaging (depending on the pair you get, but they are all good in that regard compared to IEMs).
Now that you have those buds, check out that song I sent you from Tesla. It has some REALLY separated things happening to my ears.
Now, see, I love that they can still do that after two years. to sneaky lil' bastards....Are you maybe talking about TG-38s? This happens every time after two year of using it, and they trick me every time.
They are sneaky little bastards
There is really only one thing that I don't like about them so far. It took me over an hour, and ruined 3 pads trying to get the super slippery suckers on the buds... LOL
Indeed! Metal shells are notorious for this but with practice and time one will acquire the required nimble-finger survival skill and will eventually become a breeze! Stretching them out first on an easier bud helps. But really it is but a simple finger exercise that you will learn.LOL I have some silicones on the way, because I could tell by the pics that they might be an issue trying to get the foams on that all polished metal dome.. I normally prefer foam-less anyhow and I thought the silicone would help hold them in place. Ironically, they don't hold too badly in my medium-small ears without anything (though I haven't tried actually moving around yet lol).
Funny you should mention that; after fumbling with them for a while (I got one on, then ruined 3 pads trying the other), my wife took them for about 3 minutes, and had it on flawlessly.... sheesh!Indeed! Metal shells are notorious for this but with practice and time one will acquire the required nimble-finger survival skill and will eventually become a breeze! Stretching them out first on an easier bud helps. But really it is simple a finger exercise that you will learn.
Case in point, after my lil'Siamese wife recently relieved me of my Turandots (under great duress mind you; she is vicious) I was actually banking on (hoping) having them returned when she couldn't figure out the intricate dance required to replace the foams. The Turandots are probably one of the slipperiest shells out there but no such luck! She had that figured out in no time accompanied with a satisfied crap-eating grin on her face to boot! I will never see those beautiful earbuds again.............
Have you checked if it's the plug? Sent a pair of buds back lately for repair after a similar problem developed, thought it was the cable but maker said it turned out to be the plug! HTHHi guys, I have a smabat st10 with some random cut off issues on the mmcx.
May I know if this is the famous issue with the first batch of the mmcx?
Also, is it the earphone's connector issue or the cable issue? Will this issue be fixed if i change the cable? I don't have a spare mmcx cable, will proceed to order one if it can be fixed with a change of cable.
Thanks.
I also have a green first generation Smabat ST-10 that I sent back for repair due to faulty contact in the mmcx section.Hi guys, I have a smabat st10 with some random cut off issues on the mmcx.
Thanks.
