Which is Qigom S130?is it same with Qigom S130?
Please show me the url of Qigom S130.
https://www.aliexpress.us/item/3256801813114901.html?gatewayAdapt=glo2usa4itemAdaptWhich is Qigom S130?
This MX500 type is not mmcx interface detachable model, but has the same driver.https://www.aliexpress.us/item/3256801813114901.html?gatewayAdapt=glo2usa4itemAdapt
Here is the link for it. Thanks
Thank for your suggestion. I'll consider about the Qigom model first. I think I like the Blox TM11 more. But it's quite over my budget now. Have you used any newbsound model before?This is not mmcx interface detachable model but has the same drivers.
OK. Then you can buy Moondrop U-2 along with the remaining 100usd of your budget. The Moondrop U-2 has a great wide soundstage.Thank for your suggestion. I'll consider about the Qigom model first. I think I like the Blox TM11 more. But it's quite over my budget now.
I have two DIY newbsound 32pro's.Have you used any newbsound model before?
Oh, I have the problem with my cable of newbsound and I'm fixing it. But how do you think about the Moondrop U2 vs Qigom S130A?OK. Then you can buy Moondrop U-2 along with the remaining 100usd of your budget. The Moondrop U-2 has a great wide soundstage.
It's like the Qigom S130A with its bass and power vs the Moondrop U-2 with its great wide soundstage.Oh, I have the problem with my cable of newbsound and I'm fixing it. But how do you think about the Moondrop U2 vs Qigom S130A?
Thank you so much!It's like the Qigom S130A with its bass and power vs the Moondrop U-2 with its great wide soundstage.
Both are great models, so buy both!
You're making my wallet start to cry! I want both now. I was just gonna get the qigom but I'm a sucker for a wide soundstage.It's like the Qigom S130A with its bass and power vs the Moondrop U-2 with its great wide soundstage.
Reprinted from "MOONDROP Earbuds Returns!"You're making my wallet start to cry! I want both now. I was just gonna get the qigom but I'm a sucker for a wide soundstage.
Damn...
but the design is quite strange. Is it a solid design?Reprinted from "MOONDROP Earbuds Returns!"
I listened to the U-2's all the way through after 50 hours of burn-in.
Fairly good treble and bass extension, good resolution and prtetty wide soundstage.
I hope this is the first in a new series and they release upper models.
I'm sure people are looking forward to it.
Yes, it is a solid design.but the design is quite strange. Is it a solid design?
You can't go wrong with 130 bery in any builds, same with 150 BGYou're making my wallet start to cry! I want both now. I was just gonna get the qigom but I'm a sucker for a wide soundstage.
Damn...
I'm thinking to sell my 32 pro and buy the Qigom to try itYou can't go wrong with 130 bery in any builds, same with 150 BG
Why? What don't you like?I'm thinking to sell my 32 pro and buy the Qigom to try it
