Folks, check out my mini-comparison review of
Audio-Technica ATH-CM2000Ti and
Moondrop Chaconne:
With Chaconne, I confidently ordered them from China after reading many positives reviews saying they’re TOTL. With CM2kTi, they have a lot of mixed reviews but I was luckily able to order it directly from Amazon so I basically had a free 30-day trial (after which I decided to keep them). It’s a very unique model because it’s the latest (and probably the last) premium earbud made by a major traditional Japanese or German manufacturer. And in my opinion they are easily on the level with Chaconne, just a somewhat (not too much) different sound signature.
Both earbud models offer high-end build quality with titanium housing. Each model is using a high-end single dynamic driver structure. Chaconne and CM2kTi are excellent in the timbre/musicality department. They sound great with variety of music. They’re manage to be quite forgiving and highly resolving in the details at once: so older and newer recordings are well rendered. DSD/bi-aural hi-res stuff from a proper source can showcase the quality scale these both earbuds models can reach.
Presentation is different. CM2kTi provides for a more of comparatively engaging front row listening experience with in-your-face vocals and drums; Chaconne is more of a 10th row ticket, laid-back, with various sounds positioned dynamically closer to each other. Soundstage is huge on both with great sense of space; Chaconne having a rounder presentation with more depth; CM2kTi is wider and airier. This part is a bit hard to explain but I’ll try: although Chaconne’s vocals sound less prominent in the mix overall, they are somewhat more lifted from the other sounds than with CM2kTi whereas vocals sound more prominent but less holographic.
Bass is weakest part of the frequency spectrum on both- with Chaconne extending slightly more sub-low; while CM2kTi has a bit more of a mid-bass thump. However, both take EQ pretty well with a quick low shelf bump- Chaconne responds better and can reach slightly higher bass quantities before distorting.
They’re both mid-centric, with Chaconne leaning more to upper mids with one-of-a-kind female vocals presentation: extremely clean, emotional/engaging, great vocal note extension and creamy decay. Same applies to male vocals except they could at times sound a slight bit more higher-pitch that usual (feminine?). This is where CM2kTi takes the crown with meatier, weightier, more authoritative male vocals; while females sound really, really good still.
Treble, just like mids, are outstanding on both. Non-fatiguing, yet detailed. Chaconne is more sparkly, CM2kTi is smoother. But both reach very high, with great execution in terms of having lots of quantity yet excellent harshness control.
Although Chaconne is warmer, it’s warmth is at low level comparing to something like Toneking Viridis or FAAEAL Rosemary. They both pair better with a warmer source (like Sony) that gives the sound more body, than with a clean/analytical source (like ESS chip).
Sound quality aside, CM2kTi comes with some tangible perks:
- warranty support: major manufacturer with a local office
- detachable cable: comes with 3.5mm and 4.4mm cables, along with real leather case
- light weight: can wear for longer sessions without fatigue
I highly recommend both models to all earbuds lovers (barring hardcore bassheads). Let me know if you have any questions.
