I'm more like 701 , and counting
299 more to go
Will let you know , this will be my first blurLooking forward to hearing what you think of the Blur 173 Thai Edition (PK32Ω; aka "Blur Basshead")
Is it AK? Because they sent me a $20 item instead of a $90 item and are trying to charge me for shipping it back, or paying for the item that I don't want.An expensive lesson indeed. This will be the first and final dealing with that particular seller.
I have black color, its wood shell with plastic сap on glueI did not really like the light wood finish and I think there is a dark option that seemed to be in black painted metal?
I hope they send me the correct one because the darker one is the one I like. I also order a cheap 4.4mm cable just in case more power is needed.I have black color, its wood shell with plastic сap on glue
Name and shame every time a seller/store is being obnoxious, imo.I wasn't going to mention the store out of goodwill, but yes it is AK. Looks like I'm not the only one being duped by them. Buyers beware.
Which store is your Yinman 600 with?I hope they send me the correct one because the darker one is the one I like. I also order a cheap 4.4mm cable just in case more power is needed.
AVCCK Earphones StoreWhich store is your Yinman 600 with?
One of my friends agreed with the seller to replace the stock cable with another from 2.5mm or 4.4mm Maybe this is better, the stock cable is not soft...I hope they send me the correct one because the darker one is the one I like. I also order a cheap 4.4mm cable just in case more power is needed.
