I keep forgetting to ask did we ever get a final confirmation on the correct specs for ST-10S Black-Gold? I am very curious about this.
I remember there was quite a confusing period there where the advertised specs were saying either 120Ω or 150Ω and then if I recall correctly
@DBaldock9 after testing discovered that his pair had an impedance of 300Ω or higher. I too have seriously questioned and doubt the given 150Ω impedance and 110 dB/mW sensitivity rating and do believe that mine are closer to 300Ω with a sensitivity maybe in the mid to high 90s only.
If they are indeed 150Ω / 110 dB/mW it doesn't explain at all why they sound better (less anemic) when amp'd as 110 dB SPL can be easily reached with only 0.39 volts; a current of only 2.58 mA; and require power of only 1 mW which is available from nearly all mobile sources that I can think of.
But if the impedance is indeed much higher and the sensitivity much lower this would then explain the need for them to be amp'd... I created this scenario as follows:
