gattari
- Nov 16, 2008
Pardon I replied to an old post for error.
@ClieOS, sifu, since you mentioned that only the Mojitos are wide and detailed, and seeing that they are beyond my reach, I am considering the Tings then.
In terms of details and sound-staging, how well do they stack up against the DIY Dual Drivers?
Thank-you
"VVV" as in downward pointing arrows? LOL
Gramo One and Cygnus come to mind. Actually Zen 2 and Asura 2 do quite well on mid with the right source as well. Truth being told, I really haven't noticed any particularly great mid-centric earbuds in the market right now (* not that Gramo One or Cygnus are bad in anyway either, just that they are not exactly mid-centric)
only SHE3800 really very wellwhat about philips earbuds?
I have http://www.philips.co.in/c-p/SHE2670BW_98/in-ear-headphones and have used philps she1350 http://imagenes.anunciadoentv.com/media/catalog/product/cache/1/image/1000x1000/9df78eab33525d08d6e5fb8d27136e95/p/h/philips_1350.jpg
I think the first one is almost as good as apple, but not really, biased opinion since I have been using them for a few years now, they sounded a bit better with my iphone 6s than my iphone 5, but I guess that was expected, I am pretty sure there are many other philips earbuds that would be better, I just got these because they were on sale, although now the she2670 cost about 20 aud on ebay, I got them for just 5
https://m.fasttech.com/products/0/10005987/1460600-philips-she3800-3-5mm-earphone
if you are lucky enough to catch a good pair
Of all the earbuds I have tried, Cygnus is closest to Mojito, but it is still less neutral & wide than the Mojito, and I have never heard any earbud nearly as detailed as Mojito either.
Personally I am waiting to find a cheaper (sub $100) earbud which is very similar to the Mojito. I don't know if it'll ever happen, the Mojito is truly a marvel. I'm sure it'll disappear from the market one day and become a thing of legend.
Thank-you
If Mojito's soundstage is a 10, then DIY dual driver is probably an 7.5 and Ting is probably an 8. Ting is rated higher than DIY D.D. because its has a more laid back and slightly more 3D (mostly thanks to its more robust lower end) presentation.
As for detail, also with Mojito as a 10, DIY dual driver will be an 6 and Ting will be 7.5. Ting is rated higher because, unlike DIY D.D's high which gets a little grainy on higher volume, Ting's high is more delicate.
Thank-you for the informative reply sifu.
Okay, I shall seriously consider my purchase for the Tings then. But those Mojitos though........Wish I knew about them back when they were still 700++RMB.
The $300 price tag is kind of a deal breaker for me. I can't spend that much blindly on Ali...
