Dobrescu George
Reviewer: AudiophileHeaven
I now have Eros Earbuds in my possesion. Time to listen
Those look exactly like the Hyck100 but with another cable. There's not much info to find about them. I think ClieOS has a pair so maybe he can tell you if they're good.
The cable on my old PureSounds PS100-600S 600Ω is dying... thinking on either re-cabling or simply replacing them with a pair of PureSounds PS-100 500Ω or K's K600/K500 as I desire the same ear-friendly sound signature.
Any/all advice welcome.
The real downside, as far as I can tell, is that you actually believe you probably have to spend $100 to get a cable that is worthwhile. If I have $100 in my budget, it will go straight to a new earbuds (or two, or three... you get the idea) instead of new cable, as I am more of a 'practical user' when it comes to cable - meaning I only buy cable I deem practical in use, not based on how euphonic it might / could be. Why? because almost all cable sellers are selling their cable on the cable's imaginary euphonic value rather than its practical value, and interpreting how euphonic a cable sounds has less consensus than people believing in whether earth is rounded or flatted, so to speak.
Anyway, don't really have any magical sound cable I can recommend you - but if I were to get a cable myself, I'll probably try the new FiiO pure silver cable that should be just a little over $100. As it is from FiiO, so we can at least be sure it should actually be pure silver, and you don't really get price that cheap from any other 'fancy' cable maker.
BK2...I don't like Compared in the same time with EB2, Monk+ and TO65 on Radsone ES100 and Smsl M2.
BK2 was shouty and unpleasent. For me one of the most overpriced earbuds. Build quality is good but sound is bad for me. For 20$ that i payed is acceptable but for 75$ totally insane IMO
So I got the TY Hi-Z HP150S after reading some good things about them. While sounding extremely detailed, the highs can sometimes be harsh/unpleasant within a specific range/volume, forcing me to turn it down -- it's like a drone. Anybody else notice this, or is my set busted? Feel like it kind of ruins them, unfortunately.
Just received today my Smabat ST-10 replacement pair, everything is now OK, the MMCX connectors has really been fixed from stock cable side (much sturdy and need force for the safety click.
Also, it don't rotate easily like before, it needs much force to rotate them from stock cable.
As always, Great and quick service from Jim (NiceHCK), appreciated.
I just gave a quick listen before return to work, and it sounds the exact same as my first batch (which is nice). Great manufacturing constancy from Smabat.
I tried using the thick foams from the VE ex pack but still persists. Burned in for a few hours at most. Did you notice a difference after burn-in?Mine is the TY Hi-Z AWK-F150TS (the red/blue) one. I am not sure what the difference might be but I don't have that problem. Are you using foams? Have you burned them in at all?
This information is new to me. I have one and like it a lot. Maybe a faultly unit?So I got the TY Hi-Z HP150S after reading some good things about them. While sounding extremely detailed, the highs can sometimes be harsh/unpleasant within a specific range/volume, forcing me to turn it down -- it's like a drone. Anybody else notice this, or is my set busted? Feel like it kind of ruins them, unfortunately.
Wait, just saw this - are we talking about **** BK2 here? I remember when I got mine (when first launch) it was about $43 (around RMB300) on the official Taobao store and now it actually goes down slightly to about US$39 (RMB270), not to mention it was much cheaper on some Ali. store I think any Ali seller that listed it over $40 or so are probably just looking to rip people off. Also, my BK2 definitely doesn't sound shouty or unpleasent - it is warm and smooth overall, and very easy going sound signature that is not too bad even for the $40 price tag, even if it is not a particular giant killer at that price point. For the $26 or so price tag right now at Ali, I'll say it is actually quite a good choice for anyone who are looking for a relaxing sound.. Make me wonder if we are even talking about the same earbud here.
I have another earbud with that exact same outer shell - it doesn't have an official English name but a direct translated Chinese name of 'Abbot'. This is not a common shell and I only know one earbud (the Abbot) that used it until I saw this. I wonder if they are the same earbud or perhaps PaiAudio somehow was able to source the same shell for their own driver. Just a note that the Abbot has a V-shaped sound with good end-to-end reach and soundstage, but can sound slightly aggressive at time.
We also have the red and blue(my wife does) when we first got it, I felt it was a bit sharp, we let it burn in for about 4-5 days (non stop on medium volume) after that they smoothed out quite a bit, they are fairly bright but not like they were in the beginning.I tried using the thick foams from the VE ex pack but still persists. Burned in for a few hours at most. Did you notice a difference after burn-in?
