Thank you! I thought I was going crazy not enjoying their sound, even though I thought the cable and plug looked and felt fantastic.
Is it difficult to do an mmcx connector surgery on them? I've only soldered (very badly) a few times to fix my laptop's power connector back. Do you need a helping hand?
I’ve had the same ry4s ue cable on other earbuds that I’ve never been a fan of so to me that’s the main issue. Adding mmcx is not too bad, just need the connectors, a decent soldering tip and some practice. You can get away with using a strong clip instead of helping hands, so it’s not as necessary. Pm me if you want more info.
What other changes did you make? A different cable should only make a subtle difference in the sound signature.
Just the port hole for now
