activatorfly
Ditto!Love to see your mmcx results!
Ditto!
Just ordered some kube 1 and 2. What mods do you recommend for 1?Kube V1 modded, K's Ling, Rose Mojito modded.
The Blox Yin foamless sort of sounds like a super emx500, but it's smoother and more relaxed slightly so I won't class it as an energetic sound.
where did you get the Kube1?Just ordered some kube 1 and 2. What mods do you recommend for 1?
https://www.ebay.co.uk/itm/Earphone...var=522189616760&_trksid=p2057872.m2749.l2649where did you get the Kube1?
You're right. In my case it's red and green (at least it looks like that in the picture). Didn't realize before. Thanks!Depends on the replacement wire, most have the core marked to differentiate the common from + or - Some I have had have the red as left and blue as right so I always use a multimeter to test before connecting
So I got the Yincrow X6 and the RW-9 today, and I can't really tell much of difference. there is one, but I can't really pinpoint what it is. But its minor enough where It doesn't matter too much to the music I tested it with (Time - Pink Floyd, Letter - Yosi, Enter Sandman - Metallica, Limit to your Love, and a song from Lorde.)
The bass is amazing and clear though. mids are clean and highs are strong but not overwhelming or sibiliant. The sound much better than the Sennheisers.
I might go with the X6's just because they are cheaper.
I was using a OnePlus 6T with the USB dongle to test. I do have a Fiio BTR3 i can test with over wireless and LDAC. maybe some amping will show the differences better. I will do another round of testing with the dac. I can also plug it in over USB and use it as a USB dac, so I can bypass Bluetooth issues if needed.What source did you use when you compared them both?
X6 should be more V or U -shaped than RW-9 which is claimed to be more balanced. I have X6 and have been thinking of getting RW-9.
