With some TOTL earbuds part of the cost is for the material, mainly cables, used.
I disagree, the main part of cost is the pricetag set by the manufacturer. Can it be worth it? sure, but the markup is still in the hundreds of %.
Very true, also if you consider that the TM9 and SW2+ will only sell relatively low quantity of units they NEED to set the price to a certain amount to cover the time and costs spent with R+D and material used.The cost isn't coming just from the parts or labour required to physically put an earbud together - you have to see it from the other way - it took Simphonio 3 years to develop the dynamic driver inside SWD2+ (regular price $300+, Massdrop $200). It also took Blox a few years to develop the TM9 ($280). While they might look like just another MX500 / PK lookalike, they do however deliver SQ that only a rare handful of earbuds are capable of - and that's what you are really paying for - the cost of experiment with different materials in different prototypes, plus the hundreds if not thousands of hours someone spent to make the sound just right. Those are not free.
The expense cost of earbuds is quite low (if you take what Lee from VE to be true). It costs the same to produce the the Monk as it does the Zen. The way they R&D drivers is not as scientific as a guy sitting on a lab for hours upon hours. The high cost of earbuds is mostly about what a manufacturer can get for demand.
Ok thanks again! Out of curiosity, for reference, what would you consider a 'hi-fi' option?no. It is low-fi, not even mid-fi as ak100ii-120ii. Probably, they would have enough power (though, questinable), but definitely not sound quality at all.
Just about everything is coming out of China these days, and the cost of running a business there is significantly higher now than it is a decade ago. I have been there 3 times already over the last few years, and things changed so fast it can make your head spins.
In any case, the real conclusion anyone can make is to pay whatever price level you see fit. It is pretty much a moot point regardless of whether we as consumer agree on the price or not. Remember, a few hundreds dollars worth of earbuds is nothing compared to a high end IEM these days, which has much worst value factor than earbuds. If high value factor is a must, might as well quit the hobby while you can.
EB2 ordered...
And now another thing to look forward to...
