Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
Those that has the WillSound MKx, how far these babies are from ToTL?
I'm listening now without burning and it's NOT even funny. Just WOW. Mids are popping and very life like. I think @WillSound planted some weed with the dynamic drivers. Next stop would be detachable cables. Here us?
like i always said (and i do still stand by my opinion), i like the MK1 and 2 better than the K's TOTL (and even the Poseidon), and i like the PK32 better than any other Yuin shell buds. give it some more burn time, you will be more pleased by it)
Lolaccessories aside, how does the EMX500 and the Zoomfred do in difference of sound quality?
- Nov 29, 2013
I'm still waiting to give it the full 200 hr burn in Herry recommended before I make any definitive statements about the sound. But OOTB I've noticed bigger stage/better separation (even for song with a tight arrangement), a little less bass but definitely tighter/more controlled, also the mids don't feel as recessed but definitely still slightly v- or u-shaped.
Ok, I'm listening my PK32 since 1 hour after it's first 7 hours of burning : I'm still very deceived by it. There is absolutely NO bass at all. I decided to put Heigi full thick foams to remedy on that and put +2db on infra-bass on Foobar2000 and still NO bass. I'm wondering if my pair is defect or if it's normal? it is probably the most bass-left earbud that I did tried for many years.
At least, I recognize the gorgeous natural sound from Willsound, but upper-mids are much forwarded and highs are ok but still not yet impressive to my ears. It lacks clarity and definition. PK32 clearly sounds like V-shaped reversed. Soundstage is also also not very large.
Problem is that it's not a problem of Yuin shells, as I owned Yuin PK1 in the past and it was one of my better bass quality earbuds ever.
I found listening to PK32 is a tiring experience, giving me a beginning of headache.
It is more designed for vocals only. It is not an exciting earbud.
Other than that, the build quality is excellent and beautiful (really good looking with full white Heigi foams).
Definitely PK32 is not the sound I'm looking for.
I will let them burn for few days but if the sound does not change I will put them for sale, if anyone is interested.
That is not something I wanted to hear... Lol. I just ordered the PK32. Sounds like it could have been a mistake. I hope I like the sound. Not a bass head but it needs to be there.
waynes world
- Jun 21, 2012
Considering how much @chinmie likes his pk32's, and based on how much bass @Guggga says the pk32's have, something certainly seems amiss with your pair.
I’ll try my best to chime in to when I get mine, was shipped on wednesday so hopefully that’ll be soon enough!
If it is a bad unit contacting Willsound might be a good idea?
the PK32 should sound bassiest in the beginning and would lessen on the midbass after burn in, but the bass should still be deep. it should not be reverse V shaped with no bass like that. try contact willy to discuss this
if i may, what is your other earbuds/iems/headphonea you currently use for reference?
Sgt. Ear Ache
I just got some Monk lites today. The 40ohms as they are mostly for my phone. I really like the sound! Considerably more clarity than the monk + with a larger stage and more definition of instruments. Generally more “energetic”. Not as much bass, but the bass is more defined. Fun buds...I like the fit of the smaller shell quite a bit too...
You should try the 120ohm version! It's not that hard to drive even with it's higher impedance rating. Much better than the 40ohm.
PK32 must be basshead after 10-20 hours burned and best after 100 hours burned.Ok, I'm listening my PK32 since 1 hour after it's first 7 hours of burning : I'm still very deceived by it. There is absolutely NO bass at all. I decided to put Heigi full thick foams to remedy on that and put +2db on infra-bass on Foobar2000 and still NO bass. I'm wondering if my pair is defect or if it's normal? it is probably the most bass-left earbud that I did tried for many years.
Can you share with us the recommended burn in time for each Willsound model?
Thanks everybody for your suggestions, appreciated
Can you please tell me what difference you really feel between those models in bass domain? because to me it's like 2 different worlds yet.
Mainly: Willsound MK2 rev2, MK1 rev2 (sold recently but can still remember well). If it can help I still have the following to compare : EMX500S, Edifier H180, VE Monk (rev1)if i may, what is your other earbuds/iems/headphonea you currently use for reference?
Thank you very much for your reply, I will let them burn for at least 150 hours and I will report backPK32 must be basshead after 10-20 hours burned and best after 100 hours burned.
MK1 50 hours, MK2 50 hours, mk3 50 hours, PK32 and 300 Ohms 100 hours. but after 20 hours should be better and okay to used high volume, very first time just used low or mid volume.Can you share with us the recommended burn in time for each Willsound model?
Total: 28 (members: 4, guests: 24)
