chaiyuta
May you share their sound sig?
Congrats! Yeah, indonesian earbuds sound amazing. I also have balanced MK3 here, but have not listened so far.
yup, and also don't forget the Thailand earbuds, they also pack a punch for their price. i haven't have the luck to hear the Vietnamese and Philippines earbuds yet though
Are the 2.5mm options actually balanced versions of the earbuds @ Rholupat store? They share the same images as their 3.5mm counterparts and the descriptions doesn't say much about their specs.
That being said, I have no balanced sources or amps to play with, so I'm all 3.5mm ATM...
Thanks! I already have the thin Ali foams to try out. Plus, in future, should I need to convert the Lings to balanced - I've previously made up cables with 2.5mm trrs plugs. Hence, the extended 3D soundstage swings it for me instead of opting for BS1...Lings are supremely comfortable for me. The shape is like a bell but the size is compact, fits my medium to smaller ears so well.
The weight isn’t an issue for me, because it’s distributed in the ear and the cable is very light, so it’s not pulling down at all.
I notice them in my ear so not like PK shell where you forget about them, but comfort wise they are just as comfortable.
Now here is where the issue for me becomes obvious. The bass is so strong that I was feeling too much pressure with regular or donut foams included. The size/shape was too good a fit for my ear so it was a good seal and the bass pressure was too strong.
Solution for darker/warmer sources is the aliexpress thin foams. Bass becomes perfect, tight and punchy and deep but not boomy or over pressuring thanks to the loose seal of these foams. I advise against this on brighter or neutral sources, because they will be very bright as this earbud has a high level of brightness in the mids and treble as the tuning is V leaning, the dip being just above the mid bass and raises at mids and treble.
If your source if neutral or brighter like my V20 the only solution I’ve found so far is something very unique all together. But it’s more diy stuff than stock foams so i don’t recommend it unless they already bought this earbud and need a ‘fix’.
The earbud itself is amazing, I don’t usually like V shape but this is V shape done almost perfectly (except for upper mid being too bright). It’s vocals are still foward and full bodied and the dip is not too noticeable at all. Soundstage is pretty effortless and imaging is very 3D with excellent depth layering.
I wish I had a dark source to try these on with thin foams, because they match so well with this foam but my poor ears cannot handle it on my V20... and I’m NOT that treble sensitive to begin with.
I find them to sound excellent in SE (the only option). I don’t feel the need to change the soundstage at all. It’s both intimate and spacious and extends effortlessly. Not the biggest or widest in the TOTL tier I’d imagine but wide and deep in comparison to many other earbuds.
Got recommendations for thailand earbuds, chinmie?
That’s the issue, you can find other earbuds with wonderful sound that don’t have these issues...Especially considering they're $100! ...re-considering buying these - poor fit and a heavy cable could be deal-breakers?...despite the wonderful sound signature.
Think someone on the facebook group ‘earbuds anonymous’ posted about those. You could look there.Hi, can anyone pls help me to find info on this Victor "old stock" earbuds?
After a week of diligent and disciplined burning in (more superstitious than scientific I suppose), finally listening to the Cypherus Audio buds I picked up.
If there's an interest, would be happy to share my impressions on the sound/experience of ordering.
I take it you liked the panther then? Any impressions to share?I hate this hobby, there’s always one more bud you gotta try/get!
Received Black Panther from Wong Kwan Wae last week, and now I’ve got the Blur White Chocolate ordered!
Now My poor wallet hates me as well!
