theoutsider
![IMG_6226.JPG IMG_6226.JPG](https://cdn.head-fi.org/a/10059600.jpg)
My NOS Crossroads HR1 arrived today
... the 10 year old sponge that came in the box disintegrated
Good advice, RX1 and EMX500 are different enough to make sense for a side grade. Otherwise you may as well save money for upgrade.if you already have EMX500, then RX-1 and TP16 would be a sidegrade. if you still would try them and choose only one, i suggest you try the RX, because it sounds different to the EMX, and also it has different form factor, whereas the TP16 is similar both in sound and the same form as the EMX. Different is good...you just might like them or find them better on a different scenario
Try the Moondrop Nameless. It’s in between. Great timbre for vocals and good for music.Alright, thanks again. Now I'm making my final decision between these, the AUGLAMOUR RX-1S and the TONEKING TP16. What would you say/choose?
question..
1.can you re-cable hifiman es100?
2. Anyone has listen to sharp MD earbud? good cheap budget or trash?
This post was in response to Antdroid. He bought the Masya/BS1 off my recommendation a short time ago and seems to prefer the Masya.
I’m just glad he liked earbuds![]()
Whoops I think I was mistaking you for someone else thenHeh just to be clear, I had the Masya's already but you definitely convinced me to get the BS1s.
I ended up selling the BS1 last week though. They are great for what they are, but just wasnt exactly what I was looking for. I picked up a set of Noble X IEMs with the funding and they are fantastic. Never thought I'd like IEMs but here we are....
I am considering selling the Masya's as well and just moving up to Mojito class. I've gotten a bunch of offers for them but I've chickened out on selling because it's hard to part with these ones. They are also my wireless ear buds for working out when I use them with the bt adapter.
My Moondrop Nameless arrived broken.Try the Moondrop Nameless. It’s in between. Great timbre for vocals and good for music.
And great build quality.
Did you notify the seller? If an item of low cost comes damaged or broken, there are times when the seller won’t ask you to return it, just prove that it’s broken and send you a new one. Wild Lee from VE just has you make a video of yourself cutting the item into pieces and send it to him.My Moondrop Nameless arrived broken.The stem from the bud was cracked. The box it came in was sealed and not damaged.
I bought it from AliExpress, so didn't bother with the hassle/cost of returning them.
