What's in the Willsound range?
apparently they are very good....
I've seen mention of the mk1 and mk2 and comparison with the Graphene. Also 300 ohm version, but nothing on that. Anything further would be interesting.apparently they are very good....
this my earbud bluetooth setup using the Svara L:
the thing to consider when using bluetooth, even though you might lose some quality to the sound, you gain a lot in comfort and freedom of mobility. for a bonus it also add mic for calls to the earbuds.
i personally haven't done critical a/b testing between using Bluetooth or wired, but to me the differences (if there's any) are minor enough that i don't really notice them or bothering me
@j4100 : I suggest you take an audition & comparison on both iFi Audio .. and the new FiiO Q5ii, or FiiO Q1ii since FiiO has 2.5mm balanced headphone output which is more popular than 3.5mm BL.
Even some doom metal sounds awesome
