Raketen
- Apr 5, 2010
I'm starting to feel conflicted the more I listen to my new reterminated 2.5mm earbuds. I've switched to full thick foams and the voices still sound really distant... The larger soundstage was really neat at first, but now I'm not so sure anymore. Is an earbud tuned manually after the plug? I wouldn't think so, right? (This mainly affects the QFred)
Edit: I just used a 2.5mm to 3.5mm adapter and there's no audio in the QFred's right channel. Did the guy reterminate these incorrectly?...
Have you used the same balanced source before? This description seems similar to phase issues- Might want to check the phase & make sure they are terminated correctly for your source. That could also explain if your adapter is not working because the right side could be shorting together if is not using the same pinout as your headphones. This website has some audio clips you can listen to and get an idea: http://www.audiocheck.net/audiotests_polaritycheck.php
If it is wired correctly - I haven't heard these earbuds but I have noticed BAL & SE do not always sound the same from the same source (on my DAP with balanced I actually prefer the SE)... there may also differences in output impedance etc... that affect the way matches with a particular headphone?
