Have not listened to Diomnes v2 or campfred 2 before, but K's 500ohm v2 is what I consider to be among ToTL earbuds.
What kind of sound signature does the K's 500 ohm v2 have? Is it warmer or better than the Shozy BK?
Will going from the K 500ohm v2 to something ToTL like Diomnes v2 or campfred 2 make much difference for the price? Can't decide if I should just save for the ToTL earbuds instead?
There's nothing like tubes I reckon... Something about the way they look and being able to roll them if your sound preference changes.
Yeah, I think I'll just stick to purchasing single ended as I have no use for the balanced earbuds if I only have a single ended Lyr
@slappypete beside the freq. respond on graph between Vido, NICEHCK 200 ohm and Seahf 32 ohm, how about the different in SQ from your ears?
Thanks..
musicmaker tp16Okay guys, big hard questions for my personal note cause I forget everything:
What's 5 best earbuds in this price range:
1-20$?
20-50$??
50-100$???
If you can be kind enough to answer this it will be a big help for my futur earbuds choice and the list I make for them.
1-20$?
20-50$??
50-100$???
cygnus 650 zen are more than 100No particular order, only from what I can remember on top of my head:
<$20:
EXM500
NiceHCK PK2
Yincrow X6
RY4S
Vido
<$100:
Uairekko Custom Earbuds
Shozy Cygnus
Edimun V3
TY Hi-Z 650
VE Zen
Yeah, I see this when searching price for VE Zen...cause of this I fall on headfi review that compare them to sennheiser HD600 and was like Whaaaaaaat?! IS it possible to be enveloppe in a soundstage like HD600.cygnus 650 zen are more than 100
Cygnus is around 90 usd. One can get TY650 for around 100-110 usd if you ask for discount. VE Zen is indeed more than 100 but I couldn't really think of anything else to suggest.cygnus 650 zen are more than 100
And I must admit i'm a little reluctant about buying high impendance earbud, especially more than 150ohm cause i'm afraid my Ibasso DX90 will no drive them properly (Xduoo X3 struggle with 32ohm earbuds so). I see high impendance are Always mroe expensive, and don't really understand why....as my Fiio E7 is must likely broken I don't have portable amp, perhaps should buy one but in sub-100$ amp I really don't know what to choose.
Thank you for your kind words. The Rose Masya is really good for the price. Smooth Operator.
