KookaBurrra
650 is totl earbud. it is the best earbud in my opinion way better than masya.
Thanks a lot ! I'm going to have in a few days some TY Hi-Z HP400SE, hope they are "close" to TY Hi-Z HP650!!
Killer buds incoming from my man Ryo at Uairekko Cust'm Buds!!!
Meet Sakura + Cosmos...
Have any of y'all assembled / modified any MX500 style earbuds, using the "Bass" model of these drivers? https://www.aliexpress.com/item/15-4mm-speaker-unit-earphone-driver-bass-vocal/32477644538.html
Or, have you used any of these "double unit hifi moving coil Tri-band equalization" drivers? https://www.aliexpress.com/item/15-...band-equalization-1pair-2pcs/32800609693.html
Mmm,looks tasty, I'm waiting for mine now...
@nmatheis My only issue with my Ryo buds is the cable on one of them while gorgeous, is quite stiff compared to the other, plus has a bit of memory to it. Otherwise I have zero complaints. It just came down to the wrong cable choice on my part. I'm glad I took a chance on them, and very happy to see he's getting more business in the US.
@ctaxxxx , For 2.5BL to 3.5SE L-shape adaptor, I know 2 brands. One is Effect Audio and Second is Brimar. Hope this help. For customized paint earbud, I recommend you find any gorgeous painting that you favour to use as artwork on earbud.
Do you know anywhere to get an adapter like that that is 2.5mm female trrs to 3.5mm male trrs?
Something like this:
