Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
headjelly
- May 13, 2016
Hey, is there a pocket/portable DAP which you would recommend to portable use with high-impedance earbuds, such as TY650, Puresounds 600 and Yinman 500. I am considering a Caiyn n3, but I am not sure whether it's own amping is powerful enough and I am unwilling to carry a "sandwich" around. I do own a Walnut and I hate the piercing upper mids of the second-generation fiios.
Spider fan
- Jul 17, 2011
Got my zen 2.0, i guess that my ear hole is big, because i don't get a good seal/fit without foams, like with my monks... And it doesn't sound good at all, and heard that you shouldn't use foams with the zen because it changes the sound... So... Bummer
Mine sounded thin and sometimes shrilly until I started using the rubber rings. After, I started using them it added bass and fullness to the midrange. Personally, I dont like using the earhooks because they block the ports on the back.
LaughMoreDaily
No doubt teh Zen is better than the Monk+, but how much better is it? Since we don't do blind listening tests we may never know.
The best blind tests are done with an actual blind person because when you lose one of the five senses the other ones perk up, so I hear.
DBaldock9
Can't find the link to the mantis c7 on AE, can you provide the link?
That's weird, since I did check the AliExpress store I bought from (ZS echoes Store), before making my post - that's how I knew the price had dropped to $10.83.
However, I do see now on the listing, that the C7 isn't currently available. But as I also posted - the same unit is available on Amazon under its actual brand name, of Celebrat C7, for ~$13.
nsk1
- Jan 5, 2011
Nobody interested in Blox B320 and Blue De'mun? I got it for sale.
flamesofarctica
- Nov 5, 2016
Aigo Z6 claims 16-600 ohms bit I'll let you know when I get it. Also have a Cayin N5 on the way. No idea why I went so mad :-D but I'll let you know!
Hidizs AP60 with Walnut as amp is a 'sandwich', but a compact sandwich.
Whatever happened to my Qian39?
All of a sudden I'm starting to enjoy it. Used to place this as my least favorite earbud out of my collection lol
And comfort wise, it's also the most comfortable earbud I've used!
I second your opinion, if I could I´d even shower with the Quian´s, hard to see it getting much better than they are.
leobigfield
- Oct 7, 2010
I think maybe the differences between the monks+ and zen maybe are more subtle than i first thought or what the price difference led me to believe.. But actually it isn't there or worth the extra money spent
Don't forget that Zen needs a lot of power ti really shine.
bar3336
- Apr 1, 2017
i have a lot of power - the liitle dot I + amp - i mean it sounds good and nice - with donut foams - but i don't hear a difference between them and VE monks - paid 145$ more to get the same sound?
flamesofarctica
- Nov 5, 2016
What kinds of music, as to me they sound quite different. But quite dependant on the music style. Vocal driven, or classic rock, nice big productions (Def Leopard Hysteria sounds wow), that sort of thing. Nothing lo-fi, and nothing with death metal vocals for example.
leobigfield
- Oct 7, 2010
That's really... Strange? o__O
DBaldock9
I was listening to my K's 500 most of today at work, connected to my Cayin N3, playing FLAC files of CD rips.
They sound fine using Medium or High Gain, and Low Gain will work, but the Volume has to be turned most of the way up.
130mW per channel @ 32ohm is a good amount of output for a budget model DAP.
The much more expensive DP-X1 has 150mW per channel @ 32ohm on the Balanced output, and 75mW on the Single-ended output.
You might also consider the new, soon to be released, Shanling M2s. I'm not sure about the output power, but it looks like it's going to be a good unit.
chaiyuta
I use iBasso DX200 + Puresounds 500 Pop Balanced at High gain and Volume 95/150. No need to use amp. It works fine.
Robert Turnbull
- Sep 22, 2016
Can't find it on AE, do you have a link?
Professional 14.2mm NDFEB Drive Unit HiFi in ear Earphone Music Stereo Noise Cancelling Earphones With Mic for xiaomi Phone MP3
http://s.aliexpress.com/BFJ3uamQ
(from AliExpress Android)
