Redcarmoose
Any review on Boarseman MX98? I heard this is good one with Booming Bass and warm and good Sound overall?
http://www.head-fi.org/t/441400/earbuds-round-up/3150#post_12442450
Google search ........
AkashS04 please don't misunderstand me but I think you won't find an earbud with booming bass. You'd better look for IEMs or headphones since the bass are greater on them.
Or if you still haven't tried the donut foams buy them and see if they improve the bass on your current earbuds.
Hi. I understand that In-Earn will have actual Bass but I really need to see once more if I find them comfortable. Anyway, one thing I wanted to know if Donut Foam will make bigger impact on Bass then normal cushion foam? Are they better than Cushion Foam?
Zen 2 black editionHey guys! I've been looking for a great earbud with a sound signature similar to the old YUIN PK3's. Would anyone be able to offer some suggestions? (They can be anywhere from budget earbuds to TOTL beasts.) From what others have said, the old PK3's were warm with strong, clear, and detailed mids. They also featured pretty good bass with good extension and a large soundstage. Any ideas? Thanks![]()
I'd say edimun v3 has boomy bass. I have yet to see but mag7 is said to have iem level of bass
Unfortunately these are mid to high budget.
I have the Mag7, and the bass for an earbud is truly impressive, but I know it can go further for someone who'll EQ properly (I'm a little lazy, and depending on dap not always an option) & bass boost to no end. For most, the Edimun's bass will be more than sufficient, and I know for me it's really enjoyable.
@tintheman
I enjoy listening to them with rubber rings on, you should try that![]()
And by the way, where did you buy them?
