- Mar 20, 2010
Jin do you have a semi-decent rig? It may be that Redscape is hitting your CPU, and your CPU can't take it? I dunno. I run with an 8700K, no issue.
I remember Redscape using like 17-20% of cpu just to watch 5.1 movie, and i just have a 3200G, so if your cpu is not so great like mine Redscape can use a lot of cpuI tried WZ with Redscape and it just lag. I got lower FPS and the game was stuttering. Anyone else had this issue?
Closing the Redscape app causes the output to go silent. Leave it minimized.I meant close it. Click the X. You don't need any Redscape windows open to use it, just set it as you want and close everything out.
You can close the head tracker window though.Closing the Redscape app causes the output to go silent. Leave it minimized.
Yea I have a decent rig, maybe I'm just unlucky with the software.Jin do you have a semi-decent rig? It may be that Redscape is hitting your CPU, and your CPU can't take it? I dunno. I run with an 8700K, no issue.
I unfortunately never had the real time to do a proper review of the 598. I think my time was too brief to give them a real chance. I know Senn has never really disappointed me, and I like the PC360 which was based on the 595, so it should stand to reason I would've liked the 598 just as much.I was bored and searched for the thread that got me started on my headphone obsession. It was a HD598 sale thread. I still have these headphones, and am still a fan of the 598. Was almost 1 year after this that I found this thread, and the rest is history….
Post in thread 'Sennheiser HD598 $95.00 - Amazon'
https://hardforum.com/threads/sennheiser-hd598-95-00-amazon.1883280/post-1041997743
Appreciate the insight, that's how I have it setup to my X7 but I am curious on how you'd set it up when using say an Maxtrix Mini I pro 3 or an Topping DX7 Pro? I am talking about non virtual surround at this point, connecting with a more premium dac/amp.I would send Bitstream to the X7. To make it simple, have the Xbox send Dolby Digital bitstream to the TV, and the TV must ALSO be outputting bitstream. Since you have an LG Oled (so do I), make sure to ONLY have the audio output set to Optical out. Do not do Optical + speaker or anything, because it will truncate the sound down to 2channel for some reason. I didn't realize this for a LONG time. Make sure the X7 is given a fresh 5.1 Dolby Digital bitstream feed only. No DTS, no anything else. If the TV is doing its job right, it should be converting everything to DD 5.1 anyways.
Thats what I figured, I am going to set the Xbox to stereo uncompressed and the LG CX to PCM and passthrough, correct? I am just doing it mostly because of switching amps in and out on the desk, not much room LOL. HD800s sound much better from those dac/amps then the X7 unfortunately.Oh you're using non-surround dac/amps? I just assumed you were using your X7 on the sig. Don't wanna sound like a butt, but that's the problem right there. You're not gonna get anywhere near any pinpoint accuracy with stereo, regardless of what the audio elitist lead you to believe. There's no replacement for actual surround cues.
Now...if you want Dolby Atmos with the Xbox, then you can use your non-surround gear and get accurate cues.
In any case, for setting up non-surround gear, you use LPCM to your stereo DAC. Don't use Bitstream or you'll get garbled noise.
what about redscape on a PC to s stereo dac/amp? Or do I need to buy an amp like a g7?Oh you're using non-surround dac/amps? I just assumed you were using your X7 on the sig. Don't wanna sound like a butt, but that's the problem right there. You're not gonna get anywhere near any pinpoint accuracy with stereo, regardless of what the audio elitist lead you to believe. There's no replacement for actual surround cues.
Redscape is doing the virtual surround processing already, I.e. taking 7.1 channels and converting it to 2 channels for your headphones, so you definitely only want to output it to a stereo dac\amp. You don’t want to add any processing on top of it.what about redscape on a PC to s stereo dac/amp? Or do I need to buy an amp like a g7?
