did anyone notice that Fiio silently announced a new FF3S in this answer? https://www.head-fi.org/threads/fii...1-is-officially-released.969410/post-17694739
![Eyes :eyes: 👀](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f440.png)
yes, i also would buy it again because of the feature. good prediction by youand it wasn't even on their projected release schedule.
It might just be a FF3 with detachable cable, but that would be enough for me to get it.
FiiO Lee mentioned the FF1 and FF3S would share the same cable compatibility, so that would mean a new shell / cable stem design for the FF3S. Fun times ahead coming from FiiO. It's great he had a slip of the keyboard and gave us a future release tidbit.and it wasn't even on their projected release schedule.
They don’t?Just wondering, why does high end earbuds mostly not come with replaceable cables like IEMs?
I see you own UTWS5. Have you tried these listed buds with detachable cable witn this earhook? If it is the case, please share your experience.They don’t?
I am aware that RikuBuds and TGX don’t do replaceable cables, but with the exception of the FF1, I’ve noticed that the majority of earbuds with replaceable cables tend to cost $100 or above. FF5 ($150), Yincrow RW3000 ($300), that Korean brand whose name I can’t remember now ($100+).
I do, and I have the FiiO FF5. However, my experience won’t be very informative for you.I see you own UTWS5. Have you tried these listed buds with detachable cable witn this earhook? If it is the case, please share your experience.
The UTWS5 MMCX version works great with the FF5. FF5 long stems makes it fit perfectly. I've heard others say the same as well.I see you own UTWS5. Have you tried these listed buds with detachable cable witn this earhook? If it is the case, please share your experience.
Would you please share a link to those mmcx to mmcx connector?The UTWS5 MMCX version works great with the FF5. FF5 long stems makes it fit perfectly. I've heard others say the same as well.
Yincrow RW3000 has a shorter stem, but I've made it work with an MMCX to MMCX connector. It works fine, although the same off-center stem that makes it fit so nicely hanging down, tends to roll it out of the sweet spot when connected to the UTWS5. It's good, just needs slightly more adjustments than the FF5s.
There are several buds in the less then $100 (street price) category which have mmcx connectors. Just naming a few popular choices, Toneking, Yincrow, Lun Sheng, Smabat and then there are many other non-name brand earbuds found on AE with detachable cables as well. It's really kind of a mixed bag, some low and high cost buds have detachable cable, while other low and high cost buds don't.Many on the lower end of the price spectrum don’t in order to keep costs down. But the higher end buds typically do have replaceable cables.
Besides the AE link below you might find them on Amazon as well.Would you please share a link to those mmcx to mmcx connector?
