Just got the FF5s in today and love them. I just wanted to thank you again for a great recommendation. They also look really nice in person.Hey, that's great!
Some notes for you. People have found it a little hard to discern which is the right and left bud. It's very easy. With the cable splitter with the FiiO logo facing away (forward) from you the left cable is the left side and right cable will be the right side. There is an "L" and "R" stamped into the stems of the buds, but they might be hard to see. The FF5 comes with 3 bags of foam covers. Bass, Balanced and Crisp (donut foams). The foams will allow you to tune the buds to your sound preference. I would start with the Balanced foams (which is what I use) and see how you like it. You can always swap to Bass or Crisp foams to match your sound prefs. The FF5 (and FF3) come with 2 plugs, 3.5mm SE and 4.4mm Balanced. That gives you some flexibility connecting to sources.
Also, about the LR difficulty, I noticed that there is a tiny red and blue ring right above the MMCX connector, but it is a little difficult to see. Maybe they added that recently?
I personally use a TRN TN or T2 Pro cable in MMCX (take off the ear hook shrink wrap) as they come with modular plugs and you can purchase a USB-C/lightning head for these - I have linked 1 shop on Ali that sells with the USB-C head as standard so the package as a whole would cost less but may be worth shopping around for prices.
€ 14,44 52% Off | TRNT2 Pro16 Core Earphones Silver Plated HIFI Upgrade Cable 2.5/3.5/4.4/Type C/Lighting/QDC//MMCX/0.75/0.78 MT4 Kirin Xuanwu
https://a.aliexpress.com/_EQUfthj
I'll check this out. I might just use all the adapters I have and make it work lol
