DBaldock9
Initial Acoustic [IA-PL1-YUI] 結 (ゆい) Planar Earbuds
Website: https://camp-fire.jp/projects/view/631430
Driver size: 14.2mm
Frequency response: 20Hz-20kHz
Impedance: 24Ω
Sensitivity: 102dB
Price: $150
My Initial Acoustic [IA-PL1-YUI] 結 (ゆい) planar earbud is here, and they are a sight to behold. The purple resin shell gives them a stunning look, but unfortunately, my excitement turned to disappointment when I actually tried them out.
The sound quality is just not up to par for me. It has an overly crisp and thin sound, with almost no sub-bass to speak of. This is in stark contrast to other earbuds like the Serratus or any dynamic earbuds, which offer a much richer and fuller sound. To make matters worse, the treble is so intense that it actually hurts my ears, even with the thickest foams.
I had originally wanted to compare them to the Tgxear Panorama Ridge, which is another planar driver earbud, but unfortunately, the development of that model was halted due to the creator's dissatisfaction with the sub bass and timbre.
Now I understand why planar earbuds are not quite ready for prime time yet. According to Jim from Tgxear, the IA-PL1-YUI planar driver is supposed to be the same as the one he was using, and the driver was developed for IEMs, which explains why we experienced the same issues.
It's a shame, really, because I had high hopes for these earbuds based on the early positive feedback from the Japanese users. But alas, it seems that they just didn't live up to the hype.
The "physics" of Bass reproduction isn't too difficult.
You need either:
(A.) Larger diaphragm that moves a smaller amount
or
(B.) Smaller diaphragm that moves a larger amount
Pros of (A): For a wide frequency range response, it has lower intermodulation distortion.
Cons of (A): For "fast" response, it requires a large, powerful magnet & voice coil assembly - which means a larger overall size.
Pros of (B): The overall assembly size can be smaller.
Cons of (B): Having to move farther, to produce enough Bass, will result in higher intermodulation distortion.
Because of their design limitations - planar diaphragms do not move very far, so they must be large, if you want much Bass output, when they're not tightly coupled to the ear canal.
If you have a good seal, like in an earphone with good tips, then smaller planar diaphragms can pressurize the ear canal, and produce low Bass response.
Planar diaphragms in an earbud housing, which aren't coupled as tightly, won't move enough air to produce much low Bass.
