Yeah it depends on the IEM, but sometimes an impedance adaptor is used specifically to change the sig, like with some Audiosense IEMs. I am hoping the adaptor will make the Megatron a bit less clinicalI'm not sure whether that's a good idea, given how something like Andromeda changes noticeably with just a couple extra ohm in the source or even the cable. This change is reflected directly in frequency response graphs, not just intangible aspects. But do let me know how it goes. Extending the usability of Megatron is always a good idea.
Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
tendou
- Mar 5, 2012
I am using shanling UA3 and Megatron for them.Yep I still keep my Rosemary earbud around, very warm bassy set, well suited to just chill to music. Lacks technicalities/resolution though, but there are other buds for that
What source are you using with the Rosemary? They are pretty hard to drive due to the 150 ohm impedance, but when amped properly, the clarity and resolution improves somewhat.
Ronion
- May 17, 2013
I haven’t done any real subjective testing, but in general earbud driver frequency responses don’t change much and I can only assume their impedance looks more like resistance to the amp. Only one I measured had significant deviations from baseline and that was the 32 Ohm blue glue. When I say significant, it was only around a decibel for a span of less than an octave. Not a huge deal. I only tested a couple drivers and from memory it was at 75 or 80 Ohms. My other resistor built into a plug is 220Ohms. It makes things hard to get well above the noise floor in my living room for measurements. With cans, the situation is very different and IEMs more so perhaps. Earbuds are largely immune.I’ll have a look. Interesting indeed. I don’t know what 70ohm output impedance would do to something like monk+ (64ohm). Looking forward for your subjective impressions as well.
Most dynamic driver IEM impedance graph I see is fairly flat too, I have wondered what the effects the output impedance when FR is uneffected.
Electrical damping (ability for amp to control the driver) is technically impacted by output impedance even if FR is not effected.
From testing on IE300 and CX300, high output impedance (above damping factor around 1, where driver and output impedance matching) there wasn't much audible effect and the effect that was heard I could not really call negative, just different. Extremely high (output impedance multiple times the driver impedance) does start to cause clear negative effects (grainy, muddy).
Consider that efficiency is reduced with high output impedance, with a damping factor of 1 amp needs to pump twice the power to match volume of typical high damping factor setup, amp could be contributing to heard differences too.
Ronion
- May 17, 2013
Something else I've noticed with foams. I'm not saying that this is absolutely true, but with buds that don't have a lot of deep bass, the HieGi do often add some bass. VE foams tend to add in deep bass as well, but it's not very pronounced in this case. It's always marginal and not miraculous. The treble difference is definitely the most audible difference no matter what and the shape of these changes are different with different drivers.
yup, i agree. might be because of more contact to the inner ear lobes, making the transmission of the bass frequency better? because i seem to experience that using rubber rings also increase bass response
Yeah that seems to be the overall opinion about Hiegi / dense foams. I suspect it's due to better sealing but admit it could be due to other factors as wellSomething else I've noticed with foams. I'm not saying that this is absolutely true, but with buds that don't have a lot of deep bass, the HieGi do often add some bass. VE foams tend to add in deep bass as well, but it's not very pronounced in this case. It's always marginal and not miraculous. The treble difference is definitely the most audible difference no matter what and the shape of these changes are different with different drivers.
Ronion
- May 17, 2013
I always find it interest how the foams react differently with different designs. As far as I can remember, every time a designs efficiently plays under 100Hz, the HieGi seems to decrease bass response by a dB or 2. When the design is devoid of deep bass, HieGi seem to boost the bass a dB or 2…. They always reduce treble, but different designs are affected differently. Some you can barely see a reduction in treble, but when you listen the treble sounds more clear and resolved. Others will get completely muted above a 3-4kHz, but otherwise unaffected….. while others it will be more broad and shallow. I certainly haven’t wrapped my head around the “why’s“(IOW why aren’t they all the same?) specifically, but there are definitely trends in the driver’s underlying, innate frequency response and how it reacts to HieGi foams. One thing is for sure: HieGi are a great tool for bright earbud designs. Everything I’ve heard that is bright with stock foams sound better with HieGi. If the bud is neutral or dull, stay away and look to VE for enhancements. VE foams are even more interesting….Yeah that seems to be the overall opinion about Hiegi / dense foams. I suspect it's due to better sealing but admit it could be due to other factors as well
It's a good feeling when you change a pair of foams and just this change elevates the sound from good to great/excellent (obviously it can go the other way too). It's becoming more apparent it's just as important as tip choice is with IEMs.
