This is a "one of a kind" earbud created by my brother from another mother @FranQL.What is this btw? Where can I learn more about it?
He actually made me two sets; the FQL Grand finale, and the FQL Blackhole Redux. But he doesn't sell them.
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
Are you talking about on the connectors for the Chaconne? I have not noticed this on my set (which I listen to quite a bit). If you don't mind me asking, who is the seller? Are they an "authorized" Moondrop seller?
Do you have some pictures? I will shoot some pictures and you can compare.I should have specified. I mean at the end of the nozzle, where the sound comes out. The part that is colored gold when new. And also, though it says that part is bronze, it looks similar to the rest of the bud to me.
I got them from Apos.
Take a look at the DIY Earbuds thread, you'll find a lot of interesting stuffWhat is this btw? Where can I learn more about it?
Oh, and I got mine directly from Moondrop (Amazon store).
Yep, I have had mine for well over a year now, and not a blemish on them so far. Here are the pics:I only had the Chaconnes for about a month, but I didn't have a problem with them and my guitarist has owned them for the 4 or 5 months since then and the bronze finish is still intact (I just asked). I sent a text to a fellow earbud aficionado who says he has owned them since a month after release and his bronze finish is untouched as well.
WOW! Do you have acid for ear wax? That is NOT normal, no matter what the seller says. You should contact them again (with this picture, and maybe mine as well), and if that get you nowhere, you should contact Moondrop. That is what I would do anyhow.Here's a pic after taking off the foams. You can see a little gold left in the middle, but the rest is silver (not brass) like the rest of the bud. I've only had them since May, and purchased them new.
Unless you wore them in the swimming pool, I wouldn't think they should look like that.I did send the pics to Apos and they said Moondrop got back to them and said its not a sign of manufacturer defect. I will contact Moondrop myself.
I understand the gold maybe wearing off, but its weird to me that the bronze underneath isn;t bronze color.
Now, also keep in mind, mine have never been wet, or subject to any sort of humidity, so I can't speak to whether this could happen in any sort of moisture situation.I did send the pics to Apos and they said Moondrop got back to them and said its not a sign of manufacturer defect. I will contact Moondrop myself.
It is supposedly gold plated brass - not bronze faceplate. There are copper .-zinc alloys (brasses) with nickel added that are silvery in colour, but those are rather uncommon. And I have no idea why would Moondrop choose that for gold plating and not typical yellowish one... .I did send the pics to Apos and they said Moondrop got back to them and said its not a sign of manufacturer defect. I will contact Moondrop myself.
That is a great point! I hadn't considered that they might use replacement metals during the shortages. It still doesn't make it right for what they charge for those IMHO though.It is supposedly gold plated brass - not bronze faceplate. There are copper .-zinc alloys (brasses) with nickel added that are silvery in colour, but those are rather uncommon. And I have no idea why would Moondrop choose that for gold plating and not typical yellowish one... .
It looks like they may have cut down on cost and changed the raw material - there were enormously big deficits of "red" metals in the past past year.
Preach on brother!F that! Contact Moondrop directly and see what they say. I can't think of any reason why this should be considered normal or acceptable and make sure you mention that Apos said this is all good and that they claim Moondrop signed off on this as well. If that's considered normal and not deffective for Moondrop's TOTL buds then remind me to stay away from Moondrop from now on.
