How would you compared them to the LBBs for the same genres you mentioned? Since it is my first earbud after 20 years I decided to try the LBBs first but I was also considering the Chaconne. Thanks!
I'll have a listen to both tonight and compare but my initial sense is the Chaconne has a much fuller/richer sound vs LBBs. It really is quite incredible how they present acoustics - shivers going through me earlier listening.
I'll wait for your comparison anxiously. My impression from reviews and opinions I gathered was that the LBBs having a fuller bass would be more engaging / musical. Let us know your impressions when you can.
My cantorial tracks especially with orchestral accompaniment shine with the LBBS. I only see marginal (but noticeable) improvement with my Moondrop Liebesleid. LBBS is the best bang for the buck
Most definitely concur. The Chaconne has critical fit issues for some people. The price is a tad high in comparison. And is indeed a specialist earbud as @Scuba Devils has said. A one or two trick pony only, so not an all rounder by any means. An amazing sounding earbud nonetheless.
The Chaconne fit but like mx shells, work their way out and I need to readjust. I saw a post on Facebook earlier with double foam - a donut with a regular foam over it. I decided to try and after some stressful manipulation of the foam, managed to do it! Makes a big difference and I'm not noting any negative impact to sound.
