Oh DO take your time on the impressions. Wouldn't want you to not like them because you didn't bother to "cleanse your palate", so to speak.Initial impressions on sound won't come tonight; going to take a while to build an impression for these. Truth be told, I appreciated the FAAEAL more out of the box, perhaps because of its price point. With the Smabat, the tonality is completely different, so I've got to let my ears adjust...again...before I can be fair to the M2s Pro.
As far as comfort goes, though, it's all positive. I thought the bigger diameter would have been an issue, but it's not. I can make it work around the ear and pretty easily. This cable is super-light, but doesn't feel too great in the hand. I'd rank it slightly behind the cable that came with my T2 Pro, for reference. Since it's MMCX, I suppose just get whatever cable you want at the time you order. Still waiting on my NiceHCK order to arrive, but my upgrade cable's contained inside.
I am getting better at putting on full foams, though! Only took me about 2 minutes with the M2s Pro. I don't think they need the extra upper mid/treble energy yet, so I intend to keep the donuts off for now. Took me a couple tries to get fit right since the stem isn't aligned quite the same way as the FAAEAL are, but now I can get it to slide into place effortlessly.
Going to keep enjoying them for the evening on the Honeydew playlist and the 5K and we'll see how long I can listen in one go. Have a feeling it's finite with the M2s Pro. With the FAAEAL, it's practically infinite.
Fingers crossed for tomorrow, then.
Still doesn't do justice for how small this all is...
I should be an expert at putting on the foams for those, because it looks like they aren't as slick around the edges like the Chaconne are. If so, I'm not too worried about it; I will just have my wife take over for me... LOL
I am eagerly awaiting, but since I have one set, I am content for now. Thanks though!
I forgot to post some pics of those earhooks I got from Amazon for the Chaconne. You could try them if you DO run into any issues of them staying in your ears. With these things they will probably not move from my ears should I be involved in a boxing match (and losing)....
