RikudouGoku
Member of the Trade: RikuBuds
Now thats a good idea!When I mentioned the new connection system I meant an innovative modular system that will not compromise the fit and can be easily changed. Just to mention it refers to the connection of the cable to the shell only.
For example modular cable system with interchangeable plugs invented by Dita Audio company it is slowly beginning to have wide application.
This technology was taken over by DUNU and applied on its famous CHORD, HULK, BLANCHE and NOBLE cables.
And Fiio was the first to apply the same system on earbuds (EM5 model).
Also this modular system plugs can be purchased separately
An interesting solution that could be applied to earbuds is twist-to-lock design which secures the connection firmly.https://www.aliexpress.com/item/32993028884.html
https://www.aliexpress.com/item/32921422302.html
https://www.aliexpress.com/item/1005001463529250.html
https://www.aliexpress.com/item/4000858622753.html
https://www.aliexpress.com/item/4000500282380.html
https://www.aliexpress.com/item/4001115319549.html
https://www.aliexpress.com/item/4000021771334.html
Many companies have been using this system with headphones for a long time
Twist-lock designs seems to a good alternative to traditional 2pin/mmcx connectors for iems/buds.
