RikudouGoku
Member of the Trade: RikuBuds
Are you "sharing" your music with the other people there then?Well, buds outside of the house and inside a pretty quiet co-working space.
This is a good recipe for tinnitus, I followed it and I got it. How harmless it sounds, believe me, it's not pleasant at all.Using buds outside? Arent they going to leak (disturb others) and with a poor isolation so you want to increase volume, thus risking hearing damage?
yeah, I tried earbuds outside once and felt the need to raise the volume. Thankfully I managed to hold back on doing that. outside = iems, no questions about that.This is a good recipe for tinnitus, I followed it and I got it. How harmless it sounds, believe me, it's not pleasant at all.
Earbuds or any open-back headphones, no matter how much you like to use these, just forget to use these outdoors
I agree. Also, you have a better awareness of the environment that surrounds you. Yes, there are some advantagesI find earbuds outside are only for quieter listening when I'm riding a bike, podcast type things, nothing you'll wanna pump up.
Nicehck b40 have the perfect signature for even terribly recorded voices on YouTube and podcasts, no spikes, no painful "sss" sounds.
In the case of ShoonTH ESEP-01BL, they use a special way to tune it. One side of the rear port is sealed with hot glue and that way you hear less external noise,
which further increases the effect of the closure.
I'm kind of worried about one of the ports being sealed. I would rather have a larger soundstage/imaging than better isolation since I use earbuds in a quiet environment most of the time.
Would you happen to know how the ShoonTH compares to something like the MrZ MusicMaker Tomahawk? The reason I ask is because it seems to have much more reviews with most people saying the soundstage and imaging on it are very good, but it is from 2016 so I don't know if newer buds would have technological improvements over them and I can't find any reviews comparing recent buds to them, or compared to the ShoonTH.
That's why I removed glue. Yesterday @robar discover that this driver looks exactly the same as ShoonTH ESEP-01BL. This is a better offer for 5 pairs.
With the cable (similarly braided as FAAEAL brown cable) and the shell (DP100), U can build your similar model for half the price
ShoonTH is also an old model. You can tell by the driver itself. It uses 17 holes (old-school style) on the back.
Sorry but I don't have MrZ MusicMaker Tomahawk to compare.
Fair enough Don't worry, these parts are not as delicate as they seemOh ok thanks but I don't have the tools to be making mods to my earbuds and I would be afraid of breaking something that takes over a month to ship.
I recommend to you Edifier H185 or Qian69 or NICEHCK B40.Can someone recommend a flat frequency response earbud with good imaging below $30? I was using the Sennheiser mx365 for many years until it broke. Decided to get a ve monk plus since it is raved about everywhere but found the bass too boomy and seems to ruin the imaging. I tried using Peace equalizer to reduce the bass, but the imaging seems noticeably bad to me.
I'm not sure that those listings have the exact same model, somebody needs to try both out My guess is that both worse than the N50 red rim, which has similar form factor and price. And ofc 19-21 is clearly better than thatThat's why I removed glue. Yesterday @robar discover that this driver looks exactly the same as ShoonTH ESEP-01BL. This is a better offer for 5 pairs.
