Earbuds Round-Up
Nov 29, 2020 at 12:19 PM Post #50,671 of 75,294
Lowered all earbuds ranks by 1 (except the DQSM Turandot which got dropped from B+ to C-) and added the Toneking Dendroaspis Viridis rank S.
Consider it a teaser for my upcoming review of the Viridis. :wink:
By the way, thank you for reviewing earbuds. I'm sure we all appreciate your efforts to bring more exposure to the format.
Nov 29, 2020 at 12:21 PM Post #50,672 of 75,294
Np, I agree that earbuds and headphones as well needs more exposure when it comes to chi-fi. (headphones are dominated by non-chifi brands while buds....dont get a lot of new buds at all...)
Nov 29, 2020 at 1:29 PM Post #50,673 of 75,294
Thanks for sharing this with us. You mentioned earlier (first impression) that bass has average quality. I hope that will change a little later, after the break-in period.
We recently discussed about bass vent on the front cover. I wonder if the diameter of the hole is reduced, whether it will affect the bass quantity itself.
This can be done with insulating tape and a small hole in the middle.
Nov 29, 2020 at 1:34 PM Post #50,674 of 75,294
It looks like the bass isnt coming from the center though. And I very much doubt the bass quantity will increase (i am not a believer of burn in) and if it did, it has to increase by a lot to make a difference on recing it or not (for bassy genres, like Hip-hop, EDM).
The vocals on these are really intoxicating. :joy:
Nov 29, 2020 at 1:48 PM Post #50,675 of 75,294
I'm still amazed with that positioning :smile: :thinking:
This type of shell, especially when there is no vent at the rear side, in most cases allow for a little more intimate sound, better mids, precise imaging, and wide soundstage.
Of course, it also depends on the driver itself. Is it the same in this case?
Nov 29, 2020 at 2:29 PM Post #50,676 of 75,294
Soundstage isnt much wider than the NiceHCK MX500 but it is deeper and is the first bud I have experienced some slight holographic effect with.
Imaging isnt anything special, sure it is better than the ones I have but it wont make you go wow over it...(guess the LZ A7 has increased my standards a lot lol)
Mids are godly though, the best of all my buds.
Nov 29, 2020 at 3:10 PM Post #50,677 of 75,294
I would think the bass would be focused in the center?
Nov 29, 2020 at 3:48 PM Post #50,678 of 75,294
The marking in this picture is very strange. I hope someone who is an expert for speakers can explain this positioning
Nov 29, 2020 at 5:36 PM Post #50,679 of 75,294
yeah, I got confused as well. Since I believe on 2.0 speakers, the bigger hole should be taking care of the bass. But on those pictures the treble is coming out of the center hole and then mids, bass the further away you are.
Nov 29, 2020 at 5:44 PM Post #50,680 of 75,294
There is probably no separation of where bass/mids/treble exits. The diaphragm moves air to produce sound waves and it comes out all 3 areas. It's not like it has 3 BA drivers and sound tubes.
Maybe in slightly different quantities due to the size of the openings, as the larger center will allow easier airflow due to less resistance. But all frequencies will be included. IMO.
Also @furyossa there is a rear vent. Just hard to see in most of their stock photos. :wink: toneking likes their vent near the connector and on the backside of the driver on many of their designs.
Nov 29, 2020 at 5:52 PM Post #50,681 of 75,294
hahaha, just noticed that vent lol. It is covered by the foam though.
Nov 29, 2020 at 6:02 PM Post #50,682 of 75,294
Yeah, earbud foams are porous enough that it should have very little to no effect on how the earbud sounds. At least in my experience after tuning DIY earbuds.
_________________________
I've been enjoying my DIY TWS buds made with a pair of X12 Pro and a 14.8mm 40Ω PU/Ti driver the last couple of days.
Nov 29, 2020 at 6:16 PM Post #50,683 of 75,294
You already know what I mean by "rear" vent. :wink: Not that vent. Also, this vent is 80% blocked by ear especially if worn str8-up
Nov 29, 2020 at 6:33 PM Post #50,684 of 75,294
Yeah. Your style rear vent makes (to me) an overly warm muddy sound signature. But that could just be the drivers I tried it with didn't pair well with that kind of rear air flow.
Or you know, just our personal preferences differ. :)
Give that the vent is aligned with the mmcx, the vent sits at the intertragic notch when worn down and probably exposed enough to work properly. They use the same spot on many of their buds. If it was on the left or right I'd be worried.
Nov 29, 2020 at 6:42 PM Post #50,685 of 75,294
And you are right about this. There is literally no way to perform 3 frequency separation here.
In this way, the amount of sound wave is only directed more centrally than laterally, as is the case with MX500 or PK cover.
