rprodrigues
Thank you all for the advice , i think i will opt for these: NICEHCK MX500
Here a review on them thanks to @RikudouGoku
Be aware that there are more than a version for them.
I got the "black silver mx500", not sure if the other colors are the same sound wise but the PK1 is different so be sure to pick the right one.Thank you all for the advice , i think i will opt for these: NICEHCK MX500
thanks a lot, i was about to make the mistake and buy the pk1I got the "black silver mx500", not sure if the other colors are the same sound wise but the PK1 is different so be sure to pick the right one.
What you get?Box'o'buds has arrived!
I updated the post so it should say what I got in the box .What you get?
My favorite from that pack is of course Tingo TG-38s. One of my favorite earbuds. Need some burn-in time but after that ... you will enjoy it.Box'o'buds has arrived!
Here's what I got in the box : Nicehck ME80, K's 64ohm, DIY MX760's, Dasetn MC5, Tingo TG-38s, Edifier H180 and the Awei ES10. Pretty nice selection of stuff, thanks again @rymd for making this possible!
Since it does have a different shell shape, it will sound different from the mx500 version.@waynes world
I have the pk1 version. Well, unless I got a faulty pair, they sound bad.
Yup PK1 is a smaller shell for 14.8mm drivers. It has good ergonomics so it fits better in the ear compared to MX500 which is for 15.4mm drivers.Since it does have a different shell shape, it will sound different from the mx500 version.
NiceHCK really should separate their listing for the MX500 and the PK1.Yup PK1 is a smaller shell for 14.8mm drivers. It has good ergonomics so it fits better in the ear compared to MX500 which is for 15.4mm drivers.
Sennheiser (MX500) and YUIN (PK) have set a standard for earbud shells.NiceHCK really should separate their listing for the MX500 and the PK1.
yeah, dont change it if it works should be applied more.Sennheiser (MX500) and YUIN (PK) have set a standard for earbud shells.
Anyone who uses them can rarely go wrong when it comes to ergonomics and interior design for airflow
Also, we can count DP100 and Docomo shells in this group. For me, Docomo is the most comfortable and provides the best sealing.
You’ve probably noticed yourself that many manufacturers rarely stick to the same shell design for new models, which I don’t like.
Some models deserve to be kept with possible small changes. On the other hand, you can often see some strange shell shapes that,
no matter how good they sound, destroy the overall impression, and experience with poor comfort.
