Bit of a silly request but can anyone recommend budget tips that sound really good with these two albums without the volume being loud? I might already own them but was curious what's out there.
I got my Datura pro throught the lucky box, and I was not as lucky as you. My cable is black and thin with a mic. I was so excited when I saw your post. Not sure if it is just lucky box recipients or random use of equipment. They do sound pretty good though.
That's a bummer. I wasn't aware they had differently cabled sets. It's still non detachable?
But I guess as long as the Datura Pro sounds good, that's fair enough. It is still tuned the same I would presume?
I'm listening to Hopes & Fears right now with the volume turned down lower than my normal listening levels. Will get back to you later with my findings.
Long time I did not had any new common earbuds (else than DIY ) ! just received today my ISN Audio Rambo (from Penon Audio).
It's quite a nice surprise I would say, nice details, a bit on the bright side overall but acceptable with some kind of sparkle and very good details, good mids extension and presence, but a bit bass light thought, while bass is definitely audible.
Large but coherent soundstage. Overall very pleased with this PK alternative.
I will make a full review soon, so time for some burn-in days and see if it makes some sonical changements (or not)
Cheers'
