Sad news on my replacement Smabat ST-10...it started rattling on the left earbud below 50 hz. Something didn't sound right after burning in (listening to it for a few hours) and a few frequency tests showed horrible rattling in the left ear, and some popping in the right ear. I did the sucking trick, and it helped, but didn't completely fix the problem. Maybe it's a curse, if I can't fix it tomorrow with more sucking I think I will hold off and wait for something else. My Willsound MK2 is over a year old and has no hint of rattling using the same test, hurrah for that!
Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
Willber
I've never used Paypal on AE but if you message the seller they might be able to help.Well this is weird. Tried to order the snow lotus' with my card, payment failed. Tried again, same thing. Tried to order the RY's since the seller accepts paypal. Payment eventually went through after processing for a few mins, but the order still says closed on my aliexpress account.
First time ever using aliexpress. Is this a normal thing? Any ideas how to fix the issue with paying with my debit card?
Using my credit card I have always found AE to be reliable.
Scottyyy
- May 29, 2007
I think it's a problem with the new user coupon. I just ordered the Fengru's without the coupon and it went through fine.
Unfortunately aliexpress are how holding about £25 hostage from me until they get around to refunding it. Because of a stupid coupon they offered me.
Willber
Sorry, I can't help, I've never used a coupon.
Scottyyy
- May 29, 2007
It's ok, it's sorted now. When your order gets cancelled for "security reasons" they actually take your money then refund it. How long it takes to refund the money I have no idea, but hopefully soon.
I've ordered the Fengru's and I'll order the other 2 when Aliexpress refunds me. I just won't use the coupon next time.
Willber
Well, at least the best ones are on their way!It's ok, it's sorted now. When your order gets cancelled for "security reasons" they actually take your money then refund it. How long it takes to refund the money I have no idea, but hopefully soon.
ounwx
- Oct 18, 2010
Out of curiosity, how would you describe the sonic differences between the UE and non-UE?Good choice!
(Also, I have the RY4S both with and without the UE cable. The UE is better IMO.)
ounwx
- Oct 18, 2010
In my opinion, the SL1.0+ and RY4S are quite different, to the point that I imagine most people would strongly prefer one over the other. The SL is very mid-centric and flat, while the RY4S is bright and emphasizes treble. Both have a relatively narrow soundstage and neither has a ton of bass. Hope this helps some. BTW, I have the cheaper/non-UE version of RY4S, so can't necessarily comment on the UE.Hey guys
My Pioneer SE-CE521-K's have finally died after 6-7 years so I'm looking for a replacement. I've pretty much decided on these: Snow lotus 1.0+
I've heard good things about the RY4S as well, but I'm confused about all the versions. I've heard the "UE cable" version is the best, but on the RY store on aliexpress I can't find any reference to UE anywhere. Can someone link me specifically to the best version of the RY's please? I'll buy both the snow lotus and the RY's to compare.
Thanks very much
Willber
I haven't listened to either for a long time but from memory the UE had better details and stronger lows.Out of curiosity, how would you describe the sonic differences between the UE and non-UE?
ounwx
- Oct 18, 2010
Good to know. Just received the non-UE a couple days ago, along with the Fengru Silver and EMX500. I had high hopes for the RY4S given its reputation here and my preference for brighter and more forward sound, but so far it just seems a little too thin and lacking in bass. May have to try the UE at some point.I haven't listened to either for a long time but from memory the UE had better details and stronger lows.
I'm impressed with the Silvers, considering their relaxed base signature isn't usually what I like. They are pretty inefficient and don't get loud enough driven by my phone, though. Planning to post a big comparison between the ~10 buds I've amassed so far soon.
Willber
Good to hear - real-world comparisons are always good.Planning to post a big comparison between the ~10 buds I've amassed so far soon.
BadReligionPunk
I find that the Ry4s plus mmcx has even more bass then the UE ver. Also much tighter and cleaner. My personal pick of the 2.Good to know. Just received the non-UE a couple days ago, along with the Fengru Silver and EMX500. I had high hopes for the RY4S given its reputation here and my preference for brighter and more forward sound, but so far it just seems a little too thin and lacking in bass. May have to try the UE at some point.
activatorfly
Lately been pairing Cayin N3 with NX4’s DAC....sounds superb!
Willber
Can anyone share a comparison between the RY4S Plus 32ohm and 300ohm versions?I find that the Ry4s plus mmcx has even more bass then the UE ver. Also much tighter and cleaner. My personal pick of the 2.
BadReligionPunk
@HungryPandaCan anyone share a comparison between the RY4S Plus 32ohm and 300ohm versions?
Has both. I was going to buy the 300ohm, but backed out at last minute.
