How about a "
guesstimate" on the sensitivity rating (SPL dB/mW) of other
Blur 300 Ω earbuds... anyone? This is in continuation to my other post
here.
When I get home from work this evening, I'll try a comparison of my Wong Kuan Wae "Blur 魔音" (2.5TRRS), 300Ω earbuds, and some of my other earbuds (with published sensitivity specs).
My other "higher impedance" earbuds, are:
1.) TY Hi-Z HP650 (2.5mm TRRS) - 650Ω, 120dB/mW, 12Hz-24KHz, Plastic housing, 1x Dynamic, Tethered cable
2.) K's 500-Ohm v2 (2.5TRRS) - 500Ω, 110dB/mW, 10Hz-35KHz, Plastic housing, 1x Dynamic, Tethered cable
3.) MusicMaker ToneKing TO400 - 400Ω, 112dB/mW, 10Hz-32KHz, Metal housing, 1x Dynamic, MMCX cable
4.) MusicMaker ToneKing TO200 - 200Ω, 113dB/mW, 12Hz-33KHz, Metal housing, 1x Dynamic, MMCX cable
5.) VE Asura 2.0 (2.5TRRS) - 150Ω, 120dB/mW, 8Hz-25KHz, Plastic housing, 1x Dynamic, Tethered cable
6.) Svara-L - 115Ω, 98dB/mW, 8Hz-25KHz, Metal housing, 1x Dynamic, MMCX cable
7.) VE Monk Plus Espresso (2.5TRRS) - 64Ω, 122dB/mW, 20Hz-20KHz, Plastic housing, 1x Dynamic, Tethered cable
I'm not sure how the power output changes on my DP-X1, when presented with that range of impedances, though.
