May 6, 2018 at 11:01 AM Post #30,830 of 80,206
I have applied a tiny,tiny amount of superglue between the plastic(red,blue) and the metal shell in order to avoid these kind of problems. I too have the 4 holes and single vent PT15s and they sound slightly different. The 4 holes seemy to have a open soundstage(?).
****'s quality control is not that great. One of my PT15's right side MMCX socket is slightly big and the connector falls off from time to time.
I suspect that **** buys the small, smooth-sided MMCX connectors because they're small & cheap - and then they press-fit them into the plastic bushings. It would probably add significantly to the price if they did a fit check on every one of them - and since the MMCX plugs also vary a bit in size, then a jack that passes at one test station, might fail at another one.
May 6, 2018 at 11:43 AM Post #30,831 of 80,206
Wilsound or emx500s?
Coming from pt1 and graphene
I haven't heard either, but my guess is that the willsound will blow the socks off of the emx500s :-)
(If anyone thinks that's too strong, I will edit)
May 6, 2018 at 11:48 AM Post #30,832 of 80,206
I haven't heard either, but my guess is that the willsound will blow the socks off of the emx500s :)
I have not heard the emx500 but my new Willsound MK1 rev2 is blowing the socks off me!
Costs a lot more than the 500 though.
May 6, 2018 at 12:09 PM Post #30,833 of 80,206
May 6, 2018 at 12:22 PM Post #30,835 of 80,206
Btw, I am a big fan of my DIY mx500 earbuds (before the left driver started rattling). How do they compare to the emx500s?
May 6, 2018 at 1:09 PM Post #30,836 of 80,206
Brighter than mx
Double foams with emx500 from banned seller
May 6, 2018 at 3:34 PM Post #30,840 of 80,206
That's quite a big claim and sounds really promising. How would you compare the MK1 to maybe the MK2 or 3 (if you've heard them)?
I’m sorry but I can’t answer that yet as I’m waiting for the mk.2 to be delivered and don’t have the mk.3
