Ceteru
Haha I just might. I've never felt the draw to have a bunch of headphones (a max of 4 if that much), but with earbuds I'm starting to because they're often easier to acquire, store, and use.Your best bet is a low density full foam or doubled thin foams. It’s the most balanced sound.
About the treble I think it’s smooth and slightly rolled (just slightly) but it’s definitely not under emphasised or anything. As you say once you get to a treble heavy track... It will sound treble heavy!
I think after this you will cave a buy the shozy bk and then you’ll truly experience euphoric mids and the definition of analog tuning
But for now I’ll say the BS1 is swiss army knife and capable at most genres and can handle anything thrown at it from a technical point of view.
Yep, I've tried it with several genres including metal and it's more than capable. Keeps up with drumming just fine, treble isn't too sharp unless the song is, harsher vocals aren't distorted. Haven't tried it with more extreme stuff yet, but so far so good.
EDIT for your edit: I actually used to avoid listening to Fleetwood Mac because a lot of the hipsterish people around me kept raving about it, which naturally didn't invite me to listen to them. I heard a song analysis of the song Dreams and it changed my opinion right then and there.
Video here: Worth the watch, I recommend it.
