New foam combo on my bk. This is the only combination that increases the soundstage and separation whilst also perfectly taming the high end. With the right fit bass is felt and not just heard, but I’ll have to do some tweaking to push the top piece of the foam forward for a better seal as just doing it withmy finger improves the bass impact and overall excitement of mid bass drums etc.
I came across this combo out of disatisfaction of the treble and overall balance using my previous thin monk combo. It was good but not right. So I went back to the classic heigi foam and loved the tamed treble and the bass response but didn’t like the congestion and lack of air/space. So I knew I needed something thick but also allowing air through (heigi isn’t pourous and too dense for an airy sound)
So I grabbed my new monk ex pack, took two of the new black monk thins for each side, cut both into donuts of the same size. I put one on first then the other on top. It’s a little thick but it’s workable because it’s spongy. The sound is extremely balanced, there’s space between you and the earbud so mids and vocals are not in your face and more tastefully forward than aggressively so, high’s are detailed but now perfectly tamed just to allow enough through to keep it sparkly. Low end with tampering on the fit is full and impactful. I feel like this is how the stardust should have been since day one but the wrong foams were supplied!!!
