acap13
- Jan 11, 2015
I'll need a portable solution, as most of my listening will be when away from home.
At home, I run my pc through my M-DAC with aftermarket power supply via either headphones or out through my Densen Beat power amp and into Shahinian Arc speakers.
You have a lovely audio equipment man. I adore that you have a speaker setup at home. I suppose you meant Audiolab M-Dac. That is one great dac/amp.
I wish I'm a man of great wisdom but if I could suggest staying away from more than 300 ohm impedance earbuds would be more fitting as your X5 3rd gen could drive them all well and if you want to get those 600 ohm buds, your M-dac is ready to serve the purpose at home only ( other than your hp). IMHO I think most daps nowadays have no problem driving earbuds up to 300ohm alone without needing to stack with amps which can be a bit bulky for portable purpose. Sorry man if you find my alternative as not helping. Cheers
