Danneq
Check out the specs of ATH CM7TI...
Below 20 Hz is not audible but can be felt. So as per my understanding, low freq will give more boomy sound to the earbud.Is some of that Freq response range even audible to the human ear? Finding it hard to believe without knowing the maker??
Those with large earbud collections, how are you storing them? I really need to come up with a better method, something that can handle at least 60 or so earbuds.
No need for a better methodThose with large earbud collections, how are you storing them? I really need to come up with a better method, something that can handle at least 60 or so earbuds.
New earbud from TY Hi-Z and they're now using a different shell: https://www.facebook.com/permalink.php?story_fbid=413352862370144&id=100010863017577
Store on the Cloud.Those with large earbud collections, how are you storing them? I really need to come up with a better method, something that can handle at least 60 or so earbuds.
Interesting...
So yeah, what's the difference between the "old" and the "new" 32Ohm?
They usually last longer if you treat them with care. A good rule is - budget stuff for listening when outside and high end earbuds for when you listen more concentrated at home...
