notamethlab
- Feb 23, 2014
Just one?
I've killed 3 pairs so far. This time the diaphragm separated, stayed in the cover and the copper wire snapped
Just one?
WHere can i buy it ?
I need a earbud with good bass and soundstage. I'm a basshead. My budget is under $300. And it can pair with my sony wm1a orwalnut v2 without an amp. I prefer it can swap a cable with mmcx, because i have a extra silver cable from my vegas. If not its fine. Any recommendations ? I just bought a zen 2 but i don't like the sq.
Even if the voice coil separated, if you can put it back without crunching it, it should be salvagable.
The biggest thing i've learned about working on that style earbuds.... have tons of backups around. I've come to learn any amount of a "click" or "crunch" sound on reassembly means it's time to start over with that driver/
I think sony 808s are considered the current basshead earbud champs?
Read it several times, and I still can't figure out what do you mean by "crunching" the driver?
VC separation? Yes. Crunching? No idea what's that?
The only ways i have done this are badly reassembling an earbud during DIY, stepping on them or something like that...
With all respect and more to @Danneq
- the CampFred does not like to be listened to at loud volumes, so I would definitely not amp it and EQ it like this. So, i can't call it a basshead bud, if you can't even listen at high volumes un-amped.
CampFred is fine at loud volumes. But not ear splitting volumes. Of course some people do like to listen at such volumes. I have yet to hear a low impedance earbud with as deep and solid sub bass as CampFred. It doesn't even need EQ to give you deep sub bass (although I usually EQ sub bass up by 2-3 dB).
So if you want bass and nothing else, perhaps go with something else then CampFred. For a pair of earbuds with great dynamics and sub bass and pretty good soundstage and instrument layering, I consider CampFred to be among the best when it comes to low impedance earbuds.
You can buy spare front covers from taobao. If the earbud is too tightly glued on, use a cutter plier & cut around the sides of the front covers where the glue is. Then it will be easier to pry open. After that, I try to "push it out" by feeding the cable from the rear of the earbud. And also, using a toothpick against the driver solder-board, to gently pull it out.
Btw, glad to see you back, Mr. Blu-tac!
