Is it hard to recabled a Sony MDR E808+? (How hard is it to open the shell)
If it is not, I may get 2 to recable along with my Zhisan purchase on Taobao.
Hardly any glue used by the factory. What I do is, first, try to rotate the front cover (it won't) by twisting with thumb & index; this should loosen the glue. Then pry open the cover with thumb, while using index to keep the opening as small as possible. Lastly, insert a toothpick behind the driver to gently push out the driver/cover, while feeding the wire through at the same time. Be careful to keep the entire driver/cover assembly together, I masking tape them to keep them together until re-assembly.
I not listened to them with stock cables, only recabled, mids are recessed, and they don't like high gain, highs grainy, but not scary
I have used my first E808+ for, I estimate, easily over 300 hours. The v-shape sound will flatten slightly with lots of use, and will get warmer. And there will be less grainy/splashy highs as well. My second E808+ I am using (about less than 200 hours) sounds thinner, grainy/splashy highs & bigger mid-bass hump. About the same sound character as my first one at this point of usage.
Hmm, sounds like with stock cable
I am guessing 18-strand, 0.05mm/0.06mm diameter copper wire is probably the best bet for improving the sound without exaggerating the v-shape too much. That will be my next test, once I get the things in. BTW, cable route hole is 1.65mm.
Be careful when disassembling: they have no glue at all, and breaks down at the opening of separately: the membrane with a coil, body with magnet and the front plastic cover ..
Completely agree! Have to be very careful not to tear away the ultra-thin voice coil wires, or bye-bye $3.86. Best to have a few spares around, just in case.
EDIT:
Is @ozkan around the forums? Not played with the vent foams yet, but it affects the sound heck of a lot. IIRC, @ozkan was the master of vent-related mods. Anyone tried messing with the vent foams yet?
