mindbomb
- Apr 3, 2012
How does waves nx handle the situation if you have a 2 channel dac? Does it create a 7.1 sound device?
I have another question IRT connectivity but you may not be able to answer since you may not have a set of Penrose X for testing. I've heard a few rumours that the Penrose X will work on both Xbox Series X and the PS5 but not the other way around (meaning the Penrose for PlayStation will only work on PlayStation).That's a good question, I'm gonna give it a go. I have a usb C to big usb A to connect my 8bitdo wireless controller adapter to my Nintendo Switch.
I'll report back.
EDIT:
Can confirm: THIS WORKS PERFECTLY (made sure to turn off Bluetooth to know it was 100% on dongle frequency) on my Note 20 Ultra (not sure if it'll work on other phones). So if you are like at work or somewhere where you're just using the phone for audio, this is great, and will be better than using the Bluetooth, which is only limited to SBC, and AAC post launch. May as well try if/when you have a Penrose. Just make sure to get a type C male to Type A female cable, which shouldn't be hard on Amazon and other etailers.
Obviously if you are mobile, I'd probably stick to Bluetooth to not mess up your phone's port or the dongle from breaking.
ALSO!
Penrose also works perfectly with the Switch! I'd probably try and find a way to hold the cable behind the system while holding it, but yeah, this is great.
Waves NX will install a virtual sound driver, and you config the app to play out your desired audio device. The Virtual driver reports multichannel support to the apps, and mixes it down to HRTF 2.0 for your device to play.How does waves nx handle the situation if you have a 2 channel dac? Does it create a 7.1 sound device?
Yes, it behaves as a 7.1 device.How does waves nx handle the situation if you have a 2 channel dac? Does it create a 7.1 sound device?
You have many options for headphone surround sound.Do I need a special soundcard/dac for good spatial awareness in games? IE in Warzone, I need to pinpoint the footsteps as best as possible. I currently go from my computer to the JDS Element II as my DAC/Amp, and I'm selling my Focal Elear because they give me a headache. If I get a K712, should I be good to go, or should I use a different DAC/sound card? Do I need a separate software?
I tried this before and I think the reverb is too much, especially in Movie Theater mode. Sure it gives you an impression of a very wide speaker-like sound field but the sound quality seems to noticeably degrade. Maybe I will try it again later.So I decided to give Waves NX software a go. Immediately would say that of all the software based virtual surrounds, this one is the best. And the license is only $10. There is a 30 day free trial though.
Why do I think it's the best? Because they actually put some distance between you and the sound cues, which Windows Sonic, Dolby Atmos, and DTS Headphone X software based options lack.
You can chose three presets between Voice, Multimedia, and Movie Theater. Multimedia is the most balanced, but it still lacks a bit of room size. So I'd say Movie Theater is the choice I'd make. Rear audio cues are noticeably behind you, as opposed to the others. Ideally I'd make the room size a little smaller than Movie Theater, but for the sake of positional accuracy, it's fine.
I think for pure SQ's sake Dolby Atmos and Waves NX Multimedia are on par with one another. But when I play, if I have to sacrifice a little bit of SQ for surround size and accuracy, I will, hence why I use Movie Theater.
This just brings up what I wish all these had, and that is a room size slider. It's annoying that they aren't there.
So in a pinch, I'd recommend ANYONE the Waves NX software for easy virtual surround, if you don't have hardware.
Hi all! Just wondering if I could get a little help. I've been reading about this stuff for a week and a half now and I am just plain confused. I wanted a good set of headphones for PS5. I know nothing has been confirmed yet, but I slowly settled on a pair of HD560s and a G6amp. I know there are other options, but I wanted something I could buy in Canada and return if needed. Also I wanted to be able to move between my office and the living room where I game.
Am I way off base here? The cost has escalated way past what I initially was planning on spending (THANKS APPARENTLY NECESSARY AMP!), so part of me wonders if I should just throw in the towel and grab the Penrose instead. It definitely seems easier than all this wired stuff. My whole use case was music during the day in the office and some gaming at night. I've never tried open backs, but they seem to fit that use case and the sound leakage doesn't seem excessive for late night play. I don't want to wake up the whole house when I'm trying to relax, but hearing if someone needs me if helpful.
Sorry, bit of a ramble, I just want to get a sense if I'm going in the right direction. I've read all the guides and I think I know less than I did when I started....
You won't wake up the house with open backs, at the worst someone in the same room may hear some light noise, but I game about 2m away from my wife when she's on the couch and she has only noticed a couple of times.
While the headphone choice may stay the same, I'd recommend holding off until the PS5 comes out before purchasing a DAC/Amp, as we're not really sure what will work yet, ideally you want a device that can plug in via USB and provide the tempest surround track, so while the G6 may work, I don't think it's been confirmed yet.
Thanks! I edited my post a bit to make it a little more clear. Can the PS4 pad drive these headphones at all?
Could someone paint the 38x all black and remove the mic? I'll pay extra lolI second waiting on ps5 for dac/amp or purchases. If anything the 560 should at least get moderate volume on the controller jack until you get a dac/amp.
And I'd like to know who would hate on the PC38X. That headset is AWESOME. Considering that the 560 is leaner and more analytical, I'd personally go for the PC38X which is great for everything. It's very well rounded.
