- Mar 20, 2010
That's a good question, I'm gonna give it a go. I have a usb C to big usb A to connect my 8bitdo wireless controller adapter to my Nintendo Switch.Curious, do you know if the penrose works in low latency wireless on mobile via apple donger usb adapter / android equivalent?
Also great review for the he5xx! If you still remember the sound, can you compare the 5xx to the edition xx or the ananda?
I'll report back.
EDIT:
Can confirm: THIS WORKS PERFECTLY (made sure to turn off Bluetooth to know it was 100% on dongle frequency) on my Note 20 Ultra (not sure if it'll work on other phones). So if you are like at work or somewhere where you're just using the phone for audio, this is great, and will be better than using the Bluetooth, which is only limited to SBC, and AAC post launch. May as well try if/when you have a Penrose. Just make sure to get a type C male to Type A female cable, which shouldn't be hard on Amazon and other etailers.
Obviously if you are mobile, I'd probably stick to Bluetooth to not mess up your phone's port or the dongle from breaking.
ALSO!
Penrose also works perfectly with the Switch! I'd probably try and find a way to hold the cable behind the system while holding it, but yeah, this is great.
