Chastity
- Aug 24, 2002
You mean headphones.com? Yeah it's legit. It's the company that formed after Tyll retired from Headroom, iirc.
Yea, that's coolYou mean headphones.com? Yeah it's legit. It's the company that formed after Tyll retired from Headroom, iirc.
For me, my tube buffer improves stage depth, especially in front, not so much for the sides. It also enhanced sound separation, and some tubes do it better than others. So my DT-1990 image in the soundfield better. (Rear cues especially)So is it true that Tube Amp will give a bigger soundstage? And anyone in here using a tube amp for gaming? I might get a tube amp and try it out.
Hey i am just curious has anyone tried out the gsx300 gaming soundcard and how does it compare to the x3 or g6 strictly for PC gaming
https://www.eposaudio.com/en/ca/gaming/products/gsx-300-gaming-soundcard-1000201
thanks
GSX300 is basically a cut down GSX1000/GSX1200 (with the same algo, afaik).
People who have compared Creative X3/G6 to Sennheiser GSX-series could chime in.
I've only done a cursory comparison myself (and not against X3).
After a lot of research and using Mad Lust Envy's excellent guide, I think I've reached my final two contenders for a "fun", wide, open-back headphone to be used primarily for console gaming for around $200.
Philips Fidelio X2HR or the Beyerdynamic TYGR 300 R
I'm mostly a single-player guy, but not opposed to some multi-player games (non-competitively) from time to time. At the moment not planning to utilize a DAC/AMP (hence low impedance headphones), but something I'd be considering adding at a later date.
Any thoughts/suggestions on either of the above? Perhaps another set that I've overlooked worth mentioning?
I assume your transformer/amp thingy has an RCA input, so any dac will do, and there are various dacs with virtual surround dsps, like the G6/X7, GSX1000 (though you'd have to connect fro the headphone out to the rca in on your Stax powering thing.)Just a question for the people that use stacks, what do you use for spatial surround for example just in case my terms are wrong , dolby atmos for headphones, wavesnx etc....
or can i add something like the x3 to the stack.
Sorry complete noob here
thanks
thanks
Hey thanks i do not have any stack or anythinig yet i am just looking at the best route to go. I was debating on getting an x3 to start and then going from there, but then i was reading getting a seperate amp and dac and use dolby atmos or something similar might be the way to goI assume your transformer/amp thingy has an RCA input, so any dac will do, and there are various dacs with virtual surround dsps, like the G6/X7, GSX1000 (though you'd have to connect fro the headphone out to the rca in on your Stax powering thing.)
