What do you guys think about focal elear for gaming wise?
Nope, not spacious enough.
Take a K7XX with a powerful amp or a used HD800.
If that's the case, then the G6 is an even better choice than the X3 for anyone thinking of using an external DAC.There is no "apply headphone Virtualization to Optical Out" in the Speaker settings in Command.
It only has "apply Headphone Virtualization to Line out" which is the analog line out for the 7.1, not optical
I think you mistaken with another device, the one I'm using is their new Super Xfi X3
I use a G6 connected via optical to a Bifrost 2.
I also connect via USB to the Bifrost 2 for using things like Atmos for Headphones, DTS:X, THX, Boom 3D ...
Bifrost connects to a Jotunheim, I can drive any headphone I want with that thing.
Nope, G6 is connected with optical to the Bifrost 2. That enables sending SBX VSS through the Bifrost.
The computer is also connected straight to the Bifrost 2 via USB. That enables sending most kinds of software VSS through the Bifrost, like the afore mentioned ones.
I never heard the Arya. Maybe someone else here has.
Pretty sure it won't be as wide as the HD800 though, nothing is.
The whole HEK line including the Arya is absolutely made for gaming or the requirements of this thread. If you can get the Arya for a good price go for it.
I mean in the Sound Control Panel (not the Creative software) like this
but for the SPDIF Out of your G6 in the Playback tab
With the SBX G6 I don't see SPDIF out in the windows sound control panel, did you rename it that way yourself?
Ehen I configure my SBX G6 in the windows sound control panel I do indeed have options for stereo, 5.1 and 7.1.
The headphone VSS via optical out is configured in the SBC Control app in my screenshots.
