kashim
- Sep 24, 2014
better then smsl m3 or anything else under 150/200 euro?
I see, I see... but now I need something for other games. Something more immersive.i have ad700x and is great,i had k612 1year ago,switching to ad700x was awesome..more crispy and wider soundstage,but bass are baddest :/
What sources or DAC/amp are you plugging headphones into?After some suggestions, I currently own the 599's and have had them for some time, they are a great all rounder but I was looking to upgrade to something that perhaps images better and has a bit more treble.
So after reading many reviews I went with the 660S now whilst they sound good, unfortunately my ears touch the foam covered drivers. Now whilst my 599's are angled I've owned many other flat headphones before and never had that issue.
From there I started digging into earcup depth of the 1990's, and found several reviews on here mentioning peoples ears were pressed up against the drivers due to the shallow and flat earcup.
So I'm looking for any recommendations for an open back pair, with excellent imaging, soundstage not nearly as important, with a good amount of depth for the ears. I'm somewhat limited as I'm in Australia so buying off Mass isn't always an option, but I should be able to source most brands fine. Looking to spend under $650 USD.
What about some AKG K702s?
The K612 is cheaper and more accurate sounding. I'd def think there are people that would prefer them too.Those I have tried, one of my friends has them, or had them. Whilst I enjoyed the sound, and I found them comfortable I didn't find them particularly accurate. He has them hooked up to a Schiit stack.
The Dekoni pads for DT headphones are much deeper than the stock pads. I also have some large ears, and I didn't have an issue with ears touching the back area with the stock pads of the DT-1990.After some suggestions, I currently own the 599's and have had them for some time, they are a great all rounder but I was looking to upgrade to something that perhaps images better and has a bit more treble.
If you look them up on Dekoni's site, you can see FR charts comparing the pads vs stock (I would assume B pads).Oh that's good to hear, and it doesn't change the sound profile much? Trying to source them locally do you know which ones they are, there seems to be a wide range of materials? I'd prefer something that doesn't get too hot. I found these ones are they what you mean? https://addictedtoaudio.com.au/products/dekoni-audio-elite-velour-earpads-for-beyerdynamic-dt-series
These are what I have, and they keep overall to the shape, with some treble taming, esp in the 3-5KHz range, and a bit at that 8.3KHz peak. The tubes I have compensate nicely in that 3-5KHz range, and the AK4497 is a little forward in the mids, so they all mesh very well together. The dip in 10.5KHz - 11KHz will make the DT-1990 a little less airy. Mind you you could compensate with EQ, but to be honest, the sound signature is fine as is, and is more bent towards a consumer signature vs a studio one.
