PurpleAngel
I am sorry if this is off topic. If I get a DAC and amp with no mixamp, would I set the ps4 audio to linear PCM? I think I read that was the highest quality audio bit I'm still learning so open to educating
Is this an optical input DAC or USB input DAC?
If an optical DAC
Assuming that DAC you get is not designed to work with DDL (Dolby Digital Live),
(DDL is need to be able to send and receive more then 2-channels of digital audio thru optical)
You would not even be able to use the PS4's Dolby ((DDL), for headphone surround sound.
So you would have to leave the PS4's audio to PCM and I would assume also set to 2-channel output.
For USB, setting would be the same.
